+1
Because it puts you in good steed for an apprenticeship?![]()
The issue isn't that there isn't enough work out there, but that the OP has applied to work for several electrical companies and has been told his qualifications aren't enough.
He must be a bad interview if he has 3 degrees and can't get a job. Most graduate schemes ask for a degree, not because of what you studied, but because you should be at a minimum level of competency and general etiquette/work ethic. It wasn't till I went to Uni I learnt how to properly structure a document, do research, or reference credible sources.I remember years ago talking to a guy who had 3 degrees yet he couldn't get a job with those degrees so ended up working on a checkout at B&Q.
I think certain job areas are over saturated and qualifications are just a way to eliminate people from the application process. But now its at the stage were too many people have the highest mark.
That one is a less good example as a lot of small employers put significant value on MS certs as it can affect their partner status and therefore the discounts they get on juicy recurring revenues like Office 365.Its like when people go on a bunch of Microsoft courses and try to walk in to a cushy IT job. Err no![]()
It may be a surprise to you but the vast majority of folk with degrees in Geography don't go on to become weatherman/women.
I had put you in the bag of folk who say degrees are pointless and need to be specific to the job you're hiring for.I don't know what he was like in interviews. He seemed ok when I met him. Though he was on the shy side.
Why would I think geography people would be a weather person?
Isn't a weather person a meteorologist?
What is the electrical equivalent of gas safe and does OP have that?
