its a 4770k sorryNothing really in most games if you OC the CPU to at least 4.6GHZ and game at 1440p (it is a 4770k or 4790k)?
Be different if you had a newer GPU but again not night and day.
is it worth waiting for the ddr5? is that coming out anytime soon ?Going for new RAM, CPU and Motherboard will be pricey, unfortunately you originally bought in right at the end of the DDR3 era, so there is not much upgrade path.
I personally would keep the 4700k until the Intel Alder Lake which I suspect will be the part to have this year, which should appear toward the end of 2021.
If you want to buy right now, then I'd go with a B550 board and a Ryzen 5600x. AMD is killing it right now, and that chip will max out your 1080TI easily and provide headroom, for a GPU upgrade in the future.
i was just thinking to upgrade due to my CPU being 6 years old, and it does not use my Gpu to 100%Ahh ok, many will not get past 4.6GHZ and to even get there with decent voltage may be hard, the Devil's Canyon 4790k's are far better.
Maybe end of year/next winter.is it worth waiting for the ddr5? is that coming out anytime soon ?
1,920 x 1,080What resolution are you playing at?
HI, i would like to upgrade my CPU form my current i7-4700k, with this i will need new MOBO and ram, what would be the best CPU to go with my 1080TI?
im looking for best buck for money option here. thx
Was best bang for buck a year or two ago but not anymore, gets out banged for less bucks now.B450 + 3600 is best bang for buck, go for B550 if you can though
