*** Desk and Room Gallery***
19 May 2003
Saltaire, West Yorkshire
It's a combination of two different mounts. Basically an 80cm pole and gas arm that I was using on it's own before I got the G9.
I was hoping it would hold the G9 but it wouldn't :/ hoping to find something strong enough that can just hold it on the pole as don't need it to move once on.
21 Jul 2007
Newcastle upon tyne
I've been looking at the Ergotron mounts seem to do a good job but expensive.
26 May 2012
Belfast, UK
19 Jun 2009
London
@Stu It is this desk top https://www.ikea.com/gb/en/p/gerton-table-top-beech-50106773/ 150 x 75cm comes plain so you will need to sand it smooth and put on a finish which did not take long, I finished with Danish Oil and do plan on getting a Samsung G9 eventually, I can sit on it and I'm about 17st of winter insulation :p
It is a bargain for £75 and some Danish Oil was only £8 I used a cheap orbital sander spent 2 hours sanding smooth then wiped all the dust away with some tack cloths and applied the oil. I did leave each coat of oil to dry before applying another, in total there are 5 coats.
Picture of the finish in better light
yYqMF0p9G-PAMkG_0uq4PXO8Kg8IY--zV9ijOLfCly2YAIUqTtZWBiyNObW-5xagd6TGc6DtCFH9piwIOXEBye0O5vs2vOJlCs6wXduZo3NMY5B0JWTiiDN4lnewAyyaFfNkl32l-6tDGhlexK7c83k9yBy-AWEgDap-NB6SgsR_6K4fHuX1Z8oYn7fu_2cyx9_Sk3Y4tPcLII2dVo2LCLjY_RIC6gky-zr2N9j6kw4RcYZeC-X4Z766N0hZD6OV9M_yom0mPXU1lTeEHp3mSol39K_vYMF95BnkULet2uJaUZOCrF_2X60P3AtfGlOuW52N7AUvkAW6H0cvRxl5bdGR3t89ZPPaBIq2Ka3uVkd5l33FaKC8CNGR5St1FqGs_EqJM8EHQfo4V-WCH8nvLkEdO-Py89mC-ynCjFwEGB5P7yjl5sGSqKmwLf7wVUlnI735W0Xb1I4FozDvnnjKpB6vJXQ59Y_AIzrc7ta6TWkW66bwv6fZpJ0loSfFl8Ul3Q5LrRFPVJVneJKp1gpJJhwDqtGNh_s-7ftXc9XhvyfhRGPE38NLWAiel9YGxMkvr3LBd2inEYOMJLDCENdns72SO0wiGwuW8XvHv6wTBmGpTvC4Y7W8bmYE8VOPvtouna2gJjXhr6BUHdq5elrR8UZFfW5jDWIotrIy3Bso6xeSgqdP4SerxyWXJmqznc9ZzzgJjLtBEchicpwzDsVPoBuVbg=w711-h947-no
Sorry but really curious to see the setup as I’m looking at the same table top but the image doesn’t work. Would you mind sharing again please?
