Caporegime
- 8 Jan 2004
- Rutland
You can get deeper lancets, we use some pretty aggressive ones for neonatal blood samples (BD Microtainer Blue).
My diabetes is out of control, I've had my full knee replacement cancelled 4 times (3 for diabetes) and now have to use a wheelchair.
Before I'm allowed to inject myself with insulin I've got to use my glucose monitor but my problem is even with the needle device on full power not enough blood comes out and I can end up pricking myself 4 times which then hurts a bit.
All serious and joke replies welcome to get a tiny sample of blood.
I think that you and I are on good enough terms that you will take this in the humorous way that it’s intended.
Take your finger to your closest HMRC office, they are adept at getting blood out of a stone.
Get your heart rate up a bit before doing it.
I had to get some blood out the other day for one of those home testing kits and it normally takes me forever to fill the pot, up and down the stairs a few times and it was pouring out.
Hope you get better, Dmpoole.
@SexyGreyFox sorry to hear you're going through a tough time. Hope you get better soon and your knee sorted!
General health check so cholesterol, thyroid, liver and a couple of other bits.Cholesterol? Or TRT?
Lance the side of the finger, not the pads - the skin is thinner.
+1. Also blood vessels supplying and draining the finger are located on the sides. Whilst your not actually hitting these vessels you are more likely to hit a capillary. The sides of the fingers also have fewer nerve endings so will be more comfortable. Usually shaking the hand for 10 seconds and a few fist clenches is enough to get the hand warmed up and blood circulating. You shouldn't need to use a tourniquet or elastic band (certainly not too close to the actual pinprick site). If these measures alone aren't working then a bigger Lancet is needed.
PS. Good look getting the sugars under control.
This might be a stupid one, but have you tried one of your non-guitar playing fingers? I imagine your tips are fairly calloused!
Nice. I do regular blood tests too. They cost a bit but worth it to make sure everything is tickety booGeneral health check so cholesterol, thyroid, liver and a couple of other bits.
All working now, elastic band and side on.
The staff at UHNM do it really easy though on the pad of my guitar hand fingers!
17.7 this morning, got to get my scores for a week and then ring a Nurse at Stoke Health Centre![]()
