Of course it isn't:
https://images-na.ssl-images-amazon.com/images/I/61gMu2NWeoL._AC_SL1200_.jpg
You only have a single PCI-E power cable unless you somehow aren't using a CPU.
Worst case scenario isn't that it will simply switch off under load, even if your total PC usage doesn't reach 650w, a single PCI-E cable output cannot safely deliver 300w+ or power to the GPU. The least case scenario is that the cable will get fried. Second the GPU might get killed. Third your PSU might divert power regulation from other parts of the system to feed the GPU and the whole system goes boom.
Well I forgot about the semi modular part, if theres also another PCI-E cable on the hard wired cables then it should be OK.
