Permabanned
- 23 Apr 2014
- Hertfordshire
Will it be a gaming Windows? Or just a all rounder .
Not sure what you mean by that? Win 10 does pretty well on most things.
So basically they've borrowed heavily from a few high profile people who've suggested ways to make the UI better without understanding the design language and why of what those people are suggesting and rammed them haphazardly together.
I had blinds for a bit, sort of liked it but went back to normal windows.![]()
They have the icon stack on the taskbar in the middle of the screen so why not make the whole taskbar float? Seems the logical thing to do and you can then drag it around as you see fit or pin it to any edge.
Stupid not allowing this.... Design language is lost in translation it seems.
It can also be pinned to the left of the taskbar, so that might be why it doesn't float.They have the icon stack on the taskbar in the middle of the screen so why not make the whole taskbar float? Seems the logical thing to do and you can then drag it around as you see fit or pin it to any edge.
You tried win 11 already? Care to share the iso so we can play with it?At the moment it's basically just Windows 10 with a updated UI that looks more like Mac OSX. I think they are simply naming it Windows 11 because the UI update is quite the departure from the way it is currently and they probably don't want to have to deal with the hassle of people complaining about the new UI design
Of course this is a very early build of Windows 11 I am talking about ( so things are subject to a lot of change ) and its clear it's going to need a lot more work done before it gets launched. But yeah right now if you are thinking about trying out the leaked build I would suggest checking it out in a VM and not running it as your main OS
