The Ampere RTX 3080 Ti Owners Thread
Looks like the TUF and TUF OC still only have 2 power connectors? Is that right? I really expected to see 3 on them like every other card.
Hello
3080Ti Tuf OC arrived on Thursday
Benchmark:
https://www.3dmark.com/spy/20811351
https://postimg.cc/sv6HmhMG
Welcome and on TROH.:)
The Roll of Honour.
Date 12/06/2021, Make Asus TUF, LOLN1, Link
Date 09/06/2021, Make EVGA FTW3 Ultra, therealjustin, Link
Date 07/06/2021, Make NVidia FE, K4Y84, Link
Date 07/06/2021, Make NVidia FE, mikeym, Link
Date 07/06/2021, Make NVidia FE, thor, Link
Date 06/06/2021, Make Asus TUF, ceeK, Link
Date 06/06/2021, Make NVidia FE, kamz, Link
Date 05/06/2021, Make NVidia FE, PurePickage, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your RTX 3080 Ti
The Roll of Honour.
Thank you
do i have to post photos with my name??
Just got my msi suprim x 3080 ti it is a massive card
just some cable managment to do sometime just want to mess around with the card at the moment tho
First time having a top end gpu also
no coil wine also after dealing with my 1070 for a few years glad to have a slient pc at last
The Roll of Honour.
Date 14/06/2021, Make MSI Suprim X, smithy83, Link
Nice! I have wanted a Suprim X since they first came out. For the silence!! They seem to consistently score very low on noise. Also very few reports of coil whine.
Alas... I never see stock alerts for them. I did back in Jan, but back then £950 seemed too much for a 3080.... how times have changed. Pay that in a heart beat now.
@latepmas
Yep, I've been keeping an eye on temps. Generally lower but with MSFS2020 in VR with lots of SS, I went up to 98c but GPU temp staying below 80c.
An hour of Quake II RTX had my memory go up to 100C, GPU still in the 70's.
At least there is a three year warranty, do you have to register for this?, puts me off fitting new pads or a water block
Hey I have the palit gaming oc 3080 ti and I just wondered if someone could help? Over overclocked mine as you do, when gpu utilisation is sort of 70% and below it normally boosts and stays around 2 and 2.1ghz, but when I play a game that has really high gpu utilisation that drops and drops to 1.850 or so when at nearly 100% gpu utilisation. Is this normal and how a founder edition card performs at least? Im panicking now and worried I should have got a founders edition instead? Thanks
That's normal behaviour of these cards, founders or AIBs. Nothing to worry about and your card is working exactly right. Read some reviews , Gamers Nexus even shows this behaviour on a graph.
Brilliant thanks, I did read reviews but didn’t find anything specifically detailing this behaviour. Ok so I’m good, I don’t need to sell it and get a founder edition then?
You don't need to sell it no and you may even find the FE is slower than the card you have now as it has a better cooler than the FE and a cooler that is used on their 3090 cards too, it's a very good card and your boosts speeds are very good, it's normal it settles to a slower speed as it heats up and yours is settling at a very good speed. It all comes down to airflow and case cooling too, so the better the cooling the better the boost clocks. Stick a picture up of the inside of your case showing the cooling setup, maybe can get some better fans or add more fans, but reality is your card is behaving very well so no need by the sounds of it.
Thanks. It’s a very clean setup using a b550 gigabyte vision d and an amd 5800x with an arctic freezer 280 aio. Case is a phanteks p600s white. X3 140mm intake and then x2 140mm exhaust and a single 120mm exhaust. Oh and it’s on a Corsair rmx white modular 850w psu. And using nvme drives for storage so no hard drive cadeys blocking airflow, super clean super open inside. Temps tend to stay in the 70s while gaming (regardless of the gpu utilisation). I’ll post a pick tomorrow.
It’s not the 3080 ti I wanted, I want a gigabyte vision to match my mobo, but beggars can’t be choosers right now and was just worried I’d made a huge mistake in this one.
https://postimg.cc/9zBRmTvq
https://postimg.cc/RW2qsTn2
Arrived on Saturday morning, eventually got around to posting
The Roll of Honour.
Date 15/06/2021, Make NVidia FE, latepmas, Link
I'm aware the first two photos don't have my screen name on it, but the box is up in the garage roof now and I didn't think of it at the time! :p
I believe I'm the only person I've seen so far who's taken the 'legs akimbo' approach to adaptor fitting :D
The Roll of Honour.
Date 19/06/2021, Make NVidia FE, Karl, Link
