Having a TPM module plugged into a motherboard is the old way. They're all scalped so anyone needing this is sol.
The new way is to enable a feature of your CPU. (CPUs from last 5 years)
This can be done in the BIOS. It's in a different place depending on motherboard manufacturer, so hard to give instructions.
For AMD it's called fTPM. For Intel it's called PTT.
Some people enable it then the PC Health Check app says Win 11 is supported.
Some people enable it then the PC Health Check app says Win 11 NOT supported.
Some people enable it and it works initially, then a bit later on it doesn't work anymore.
So my i5-4690k/Z97x gaming 7 mono is SOL then I take it with this if it stays a requirement when the retail version is released.
)I got this successful
https://i.~ibb.co~/hst8ZMY/2.jpg
My guess is that it's here...
AMD have said you can enable fTPM in the BIOS with Ryzen CPUs:
However,the problem with fTPM,any reason which leads to your BIOS being reset,etc like memory tweaking,overclocking or updating a BIOS,will cause issues,and you will need to revalidate stuff. People will need to remember the keys - how is that going to work for most people??
Apparently Win11 PRO can disable Bitlocker so there might be an avenue out of fTPM getting in the way.
A bigger issue though is secure boot - how is that going to work if you dual boot??
Even if the TPM issues is easily sorted by module or BIOS setting the processor requirement is going to catch a lot of people out - for Intel https://docs.microsoft.com/en-us/wi...pported/windows-11-supported-intel-processors - 7700K and earlier look like theyre out of luck
What when you flash the BIOS with a new version when using fTPM?
Github App to test why Win 11 fails:
Windows 11 Readiness Check (WhyNotWin11) - Programs, Apps and Websites - Linus Tech Tips
