- 4 Feb 2018
Does your cheap bin have legs? No? Then shut up.What does a £250 bin do that my £5 bin doesn't?
£245 worth of legs, gotcha.Does your cheap bin have legs? No? Then shut up.
Then you sir found a bargain, a very good bargain. Well done.Yes it does. Well not strictly legs per se, but three raised sections that lift it an inch or two of the ground.
I mean the silicone! If you're getting foams you can't really report on the silicone ones though. I should probably just order some myself.
Lol
It was a bargain £150 on prime day. Nice legs - allow the dog's bowl to be hidden away underneath.
Lol
To be honest I bought this bin for £120 a few months ago, so £150 isn’t crazy.
https://www.amazon.co.uk/dp/B00O9ZF...abc_PMPM7C0FBCJ00XC296FM?_encoding=UTF8&psc=1
I'd recommend Simply Human if you're after a bin. The lid on just mine broke so I contacted them on Wednesday night and no questions asked they sent me a brand new bin that arrived today. Not bad when I bought it just under 6 years ago.
New kitchen bin thing...
Is the hand written name so you can sell it on eBay for scalp prices?
Is the hand written name so you can sell it on eBay for scalp prices?![]()
