Sadly you will get a reply saying it's normal and working within spec.
As others have said here FE cards 3080 and 3090 all hit high VRAM temps, anyone telling you they don't is either water cooling (now they even sell backplates that are water cooled) or lives in an igloo. The FE cards look great and better value than AIBS but they have problems too, like the terrible thermal pads, coil whine and high temps on the VRAM if placed in a case that is not a wind tunnel. We had over 28 3090s at work in NVLINK (dual 3090s) and all caused us some problem in time or right out of the box, they would whine so bad or have fan rattle or they would sound like hairdryers because of the temps and these were in highend workstation class cases with very good air flow (take that as cases with fans running faster than normal case and a lot of air flow, office is air conditioned too to keep the work area cool).
In the end we returned them and the ones they refused to accept as returnable we sold on ebay and purchased AIB blower cards and normal 3 fan AIBs that were a lot better and none have caused us any problems with temps or bad coil whine or noises of rattling fans or fans going 100% and sounding like a hairdryer, yes the systems are not silent and never will be how we use them but they are so much better now and none of the horrible nail scraching coil whine or fans rattling. Sadly the only good thing about the FE cards is their price, they look good and great for people to water cool if you end up with one that doesn't whine, if it whines and you water cool it you will find how much you wil hate the sound these cards make.
Then Nvidia sell a 3080Ti with a 3080 cooler a card that can use 400w
. Just wait in time you will here all the people returning them for many reasons, from heat, whine to fans running really high rpm.
