Ryzen 5 5600G and Ryzen 7 5700G coming in August.
21 Jan 2010
UK
They are price at $359 and $259:
https://www.techpowerup.com/282800/amd-announces-ryzen-5000g-and-pro-5000g-desktop-processors
So it should work out at approximately £300 and £220,if you include VAT and current exchange rates. Changes over the CPUs include a reduction in L3 cache to 16MB abd 24 PCI-E 3.0 lanes instead of 24 PCI-E 4.0 lanes. Essentially these are the Ryzen 7 5700X and Ryzen 5 5600 non-X in the range for now.
If this is the approximate price for a 5700G (£300), then count me in. I'll keep an eye out for this. Does OCUK have pre-order notifications by email once expressed an interest?
15 Oct 2019
Uk
I can see the merit in these CPUs if you want to run without a GPU but for someone looking at one as a temporary measure until they can get a GPU or as a discounted 5000 series then the performance with discreet graphics is quite weak and more akin to a 3000 series CPU and even quite a bit below Intel 10/11th gen which can also be used in that situation.
13 Jun 2012
Reading reviews online, shows the performance roughly equal (270X probably ahead by ~5%).
Saying that, in modern titles that integrate FSR it will probably lead to the desktop cezanne chips being 20% faster!
**Please Creative Assembly, put FSR in Warhammer 2 so i can game on an ultrabook...**
Stu
Stu
19 Oct 2002
Wirral
For those eyeing up these chips as an alternative to a 5600x or 5800x, is the lack of PCIE4 support going to be an issue next year when Direct Storage starts being implemented?
Man of Honour
22 Jun 2006
Last I heard, PCI-E 3.0 will work fine with DirectStorage?
Stu
Stu
19 Oct 2002
Wirral
I'm aware that it'll work, but will there be a significant performance hit for PCI-E 3.0 vs 4.0? Idk, but I'm sure someone more technical than me can work it out. In reality, I'm guessing there will be a notable difference on paper/benchmark, but little difference in user experience.
27 Apr 2007
The NVMe protocol is an important part of DirectStorage I think, which is why PCIe 3.0 will also gain.
When you consider that a high end PCIe 3.0 drive will beat a low end version 4 drive, it would make no sense to disqualify them.
So yes, MS will probably make PCIe 4.0 mandatory. :D
As for how much the higher bandwidth of PCIe 4.0 will help, too early to say.
15 Oct 2019
Uk
The Xbox series X runs a mid range gen 3.0 nvme perfectly well with direct storage.
7 Oct 2004
Does anyone know if the 5600g and 5700g will be compatible with the MSI B450m mortax max motherboard? If they are, what ram speed would people recommend for a low power home server?
Man of Honour
22 Jun 2006
Not on the CPU list from what I can see. Do you know which agesa they arelte to?
27 Apr 2007
I find it really confusing as the update for Ryzen 5000 series CPU was released a while back, just not sure if that means the 5700g though
I doubt it as they are a different series of chips.
The APUs or whatever they call them now were released later, so will require a newer firmware update.
You need to look at the manufacturer's site for precise details.
