- 26 Jan 2009
- Swindon, Wilts
Can you delid these? I thought they were soldered to the IHS.
Intel has soldered the IHS since the 9000 series.
If it's soldered then you don't want to even try!.I dont know if I would be comfortable or not deliding the CPU anyways, im happy with the temps atm anyhow..for such a hot chip / chips, I am satisfied...for now
Better heat transfer.Yeah, for sure.
Why do they solder them anyways??
Played some FC5 ND again, the average temp for all 10 cores were mid 50s. So pleased with that!
One core though, (core 6) was a lot higher for the most part than the rest? Is this the core using single boost, hence why its was slightly hotter??
