Can i put 3600 Ram in motherboard that says max 3200?
5 Aug 2006
Northern Ireland
1866/ 2133/ 2400/ 2667Mhz (by JEDEC)
2667/ 2800/ 2933/ 3000/ 3066/ 3200/ 3466 MHz (by A-XMP OC MODE)
that what it says on my MB, but i bought 3600 ram by mistake and i wondered if it will still work in my pc
as i dont want to damage anything.
the Ram is Crucial Ballistix BL2K8G36C16U4R 3600 MHz, DDR4,
i have B450-A PRO
If you have one of the later ryzen CPUs like 3000 series + then it should work fine running at 3600mhz but if you are on 1000/2000 you may have to manually set the speed to 3200 if it gives you problems with D.O.C.P
ok thanks very much for that, i will check it out more. but seams to work ok. is there any software i can use that will tell me what speeds it running at ?
