G30 5 series buying advice
  • Thread starter Thread starter 233
  • Start date Start date
It doesn't actually have driver assist plus, it has adaptive cruise without the rest of the driver assist stuff (lane assist etc). I've never seen one with that spec it's certainly unusual.
A very good spot! How very unusual. For some reason I had it in my head that it wasn't available except for with Driver Assistant Plus. However, a brief look of the 2018 brochure shows it was £965 on its own.
Which makes the rareness of it even more odd. I'd figured the £2k cost of the package put people off. But 900 quid on a £40k car...
My 530e was delivered yesterday.
Pretty amazing car really and in surprised at how easy to drive it is. Coming from a 2005 Fiat Panda I was expecting to take a bit of time to acclimate but really was a case of sitting in an going.
One point to look out for is whether the type 2 to type 2 cable is included. I have the three pin mains charger and the bag for the type 2, but not the cable itself...
Wow, thats some jump from the Panda, but glad you like it :).
Great cars though eh?
They don't come supplied with a public charger cable, only a 3 pin granny charger. Incidentally there is a recall out for those chargers so check if it's been replaced.
Given it came with a BMW branded bag for one that seems rather mental. Will see if I can get one through the place I bought it from, otherwise I will order one.
ok the 30e turned out to be a badly prepped dog, dealer didnt see the problem with having 3 different brands of tyre on the one car along with alignment problems so knocked that on the head pretty sharpish.
deposit down on a 520d
https://www.autotrader.co.uk/car-details/202107084778600?minimum-badge-engine-size=2.0&make=BMW&model=5 SERIES&advertising-location=at_cars&body-type=Estate&year-from=2018&sort=price-asc&price-to=22500&onesearchad=New&onesearchad=Nearly New&onesearchad=Used&seller-type=trade&radius=200&postcode=g334uf&include-delivery-option=on&page=1
only real positives is that its a touring and has HK.
spec from BMW
Ordered Options
01CA Selection of CoP-relevant vehicles
01CB ACEA/CO2 Coding
02PA Security Wheel Bolts
02TE Automatic transmission with gearshift paddles
02VB Tyre pressure monitoring
021R 19" black 664M light M Double-spoke style with Run-flat tyres
0230 EU specific equipment
0258 Run-flat tyres
03MC Roof rails, High-gloss Shadowline
0302 Alarm system (Thatcham 1)
0337 M Sport Package
04AW Instrument panel in Sensatec
04K7 Aluminium Rhombicle interior trim with Pearl Chrome trim finisher
04T8 Exterior Mirrors - folding with anti-dazzle
04UR Ambient lighting
0420 Sun protection glass
0423 Floor mats, velour
0428 First Aid Kit & Triangle
0459 Elec Fr Seats + Driver Memory
0481 Sport seats, front
0494 Seat heating, front
05AV Active Guard
05A1 LED foglights, front
0502 Headlight wash
0508 Park Distance Control (PDC), front and rear
0534 Automatic Air Conditioning
0575 12V power sockets
06AC BMW Emergency call
06AE BMW TeleServices
06AK BMW Online Services
06AM Real Time Traffic Information
06AP Remote Services
06WB Digital Cockpit
0609 Navigation system Professional
0650 Single-disc CD Player
0654 DAB digital radio
0688 Loudspeaker system - harman/kardon surround sound
0704 M Sport suspension
0710 M Steering Wheel
0715 M aerodynamic bodystyling
0760 Exterior trim, High-gloss Shadowline
0775 Headlining, Anthracite
08KB Oil service interval - 24 months/25,000 km
08R9 Refrigerant
08SM External Visible VIN
08S2 Coding of alarm siren (time limit)
08S3 Auto drive away locking
08TF Active Pedestrian Safety
08TG Dead-Locking Function
0812 GB Specification
0850 Add Fuel for Export Cars
0880 English Handbook
09AA Bodyshell protection
Standard Options
0853 Instrument Panel Letter
That’s lovely, other than the black wheels :P
Looks like a very nice place to be though
see the edit above.
few things missing from my shopping list carplay is going to be a 50/50 if i can add it no active cruise boo. but its got a massive boot and will do 60mpg all day long. not as quick as the 530d i really wanted or even the 30e but as one of the reviews of the G30 touring i read said its 95% of the car you'll ever need or want
Carplay can definitely be added on that one as it has NBTEvo ID6 - it may just need an i-Step update first if you want full screen Carplay - this will be 1-2hrs labour cost at your dealership or an ENET Cable and battery maintainer at home if you're feeling brave to do it yourself (not recommended unless you know what you're doing). It will certainly support split screen Carplay without though.
as stupid as it sounds the car play is a big deal. had it on my 1 series and loved it, found it fantastic especially with waze, digging had suggested that a lot of places can retrofit the aerial if needed so wasnt a deal breaker but what is the NBTEVO? is that i drive 6.0?
Only if it has the Wifi antenna - which looking at the options list on the Autotrader advert it probably doesn't (no enhanced bluetooth listed, no wifi hotspot prep listed, no rear seat entertainment listed - you need one of these three). All isn't lost though, can buy the antenna and retrofit and code, and then get Carplay but won't be via any 'official' means.
Doesn't necessarily have to have one of those options - most NBTEvo units had them regardless - there was only around 5% of Evo units which didn't get them. It still works even without the antenna but your phone will literally have to be on the NBT unit to work and it's not difficult to add especially on the BMW units - the Mini is more of a pain due to the way the Evo unit is mounted behind the circle dash.
I suspect it was more of the ID5s that were missing them out of the 5% as well.
For me, the whole front end of the G30 falls apart without the Icon lights, which is probably on 1% of cars?
Still a great car, just annoying they fitted lights that look quite cheap. :(
spoke to the local bmw specialist not a problem at all to retro fit along with a million and one other options that can be enabled.
think i'll live without a reversing camera though, £550 fitted ouch
I suspect that would be eye-wateringly expensive though!
This is a very nice one, for anyone else looking who doesn't want a Touring: https://usedcars.bmw.co.uk/vehicle/202106244188921
Just sums up the market for me - a few grand cheaper than mine was, but mine was 11 months old with 5k on it and that one is basically 4 years old with 50k on it :eek:
I don't know how I'm going to get past this irritation as it currently stops me wanting to buy anything. It just all seems such poor value. Things have very much moved on in 5 years.
