Ah interesting - can the app override the standby switch too, or is that manual intervention only?
For the plugs, yeah or mine does anyway. It's essentially the same as using the app.
Thanks for the quick reply! yeah we would go through JL as they generally have the best after market support for large items like that. Cheers for the Top Cashback heads up! btw, do you have a smart meter and have you noticed much difference in power usage compared to the last one?
Looks good, weve looked at a few and this one felt higher quality. I've got no interest in the see through door but wanted good handing/hinging etc.
For the water feed, does it have a reservoir of water in it so it keeps it cool (reason being is I think my cold pipe is near a rad pipe or hot pipe so comes in lukewarm unless I run it for a while)
Could you buy an extra length warranty with JL?
Do you mean you have a seperate fridge still in the house also?
Not the OP but I've found this to be a fortunate coincidence. Ideally you leave the power switch "on" and then 'hope' the device comes out of standby when it gets power.
My Delonghi ESAM doesn't do that, so it gives no benefit to use a WiFi plug as it doesn't come out of standby automatically.
My IKEA kitchen lights however, remember the last state - so come powered on at the right dimness![]()
Plonk x12
I didn't care about the see-through glass but the long haired general saw it in the shop and wanted it.
You can get one with an internal 4L (from memory) reservoir. Since ours is only a few cupboards away from the sink and thus cold water feed we went for that one. I'm unsure how much it stores in the fridge but it must have it chilled as it also makes ice with the feed.
Why would you need a WiFi-enabled socket adapter? What possible features do you need from a socket adapter other than being an adapter? Does the plug change from EU to US, etc. via WiFi?
Any recent pictures of your setup?Never noticed before! Or forgot and noticed again all fresh and new. Life is exciting like that.
It's really quiet, the only noise you can hear is the ice landing in the collector tray now and then. I'm very pleased with it.Aye im going to get the plumbed version, I dislike the ones you have to fill up/never use the current one. Do you find the fridge loud? One of the key criteria for our new one is that it's quiet (current Samsung one has always been loud!)
Picked up a SilverStone Strider Gold 650W for $95. Used in a demo PC, only a few months old.
Perfect for an HTPC I'm building.
Keep us updated on cost per pizzaA pizza thing.
Now waiting for the Ooni to arrive tomorrow.
Keep us updated on cost per pizza![]()
