RX 7900XT, 15,360 cores, MCM, Tapeout Q4
28 Jun 2013
the rumors i have seen for a while are the next gen cards will be very very strong, fingers crossed the mid range cards will be as good as the current flagships
12 Jan 2021
Just hope that they are better built than some of the 3090s as power usage on next gen 7000 and 4000 series is supposed to be high for the upper end cards
7 Dec 2010
Leeds
Looks more like a compute server GPU to me with silly power usage not designed for PCIE type cards. That is if true. Also reading the article which is comical BTW, it says the 6900xt to 7900xt is 2.2x to 2.5x performance increase BUT the 6800xt to 7800xt is 30% to 40% increase (you know the typical increase seen), then he waffles on about it could be less. Reality time the 6800xt to 6900xt is nothing more than a 10% increase at max in performance, so that will make the 7900xt really only 40%-50% increase over a 6900xt by his numbers, but goes on about 220% to 250% increase...:rolleyes:
The article is clickbait and the so called 7900xt is not a PCIE type card gpu if on 7nm or even 6nm, so i'm going with a compute server gpu card if true and not aimed at gamers in any form unless you want to pay £10k+ for one.
Typo corrected should have read 6800xt to 7800xt.. Not 7900xt.
17 Aug 2009
Looks more like a compute server GPU to me with silly power usage not designed for PCIE type cards. That is if true. Also reading the article which is comical BTW, it says the 6900xt to 7900xt is 2.2x to 2.5x performance increase BUT the 6800xt to 7900xt is 30% to 40% increase (you know the typical increase seen), then he waffles on about it could be less. Reality time the 6800xt to 6900xt is nothing more than a 10% increase at max in performance, so that will make the 7900xt really only 40%-50% increase over a 6900xt by his numbers, but goes on about 220% to 250% increase.
All of it is rumour but you seem to have confused 7800xt and 7900xt.
They are saying the 7800xt will be a conventional die and be 30-40% faster than a 6800xt.
Also that the 7900xt will be a chiplet design with triple the cores of a 6900xt and that's why it gets the much larger claim of 200-250%.
I don't see anything wrong with a crazy flagship model, not about to break Nvidias mindshare by being an ok alternative.
6 Feb 2019
7 Dec 2010
Leeds
I think you need to read what is written again.
We can conclude a few things from this rumor. Firstly, the Radeon RX 7900 XT (Navi 31 MCM) should easily be 2.2-2.5x faster than its predecessor, with the RX 7800 XT (Navi 33) beating the RX 6800 XT by 30-40% despite featuring the same core counts. A lot will depend on the process on which these chips are fabbed, as the 5nm node should allow for higher core clocks, boosting the overall performance by 15-20%. If a 7nm derivative such as N6 is used instead, then we’re probably looking at more conservative gains. It’ll also be interesting to see if AMD includes any dedicated hardware for Tensors or whether the Ray Accelerators are upgraded to account for BVH traversal.
Typo corrected on my first reply. But still stands the article makes no sense. 30%-40% for 6800xt to 7800xt xt but 6900xt to7900xt is 220%-250%.
17 Aug 2009
No I'm not seeing a problem with the way I read the entire article which you're definitely not quoting. Maybe you could go into detail why you're seeing something different to what I wrote up there.
7 Dec 2010
Leeds
Read above what I added. There was a typo before on my first reply. The article makes no sense and it states 6800xt to 7800xt is 30 to 40 percent faster BUT... 6900xt to 7900xt is 220 to 250 percent faster.. When 6800xt to 6900xt is no more than 10 percent faster as it is now.. So where are they getting next gen 7900xt is going to be almost 200 percent faster than a 7800xt from? Makes no sense. The article is pure rubbish.
I also get the 7900xt will be mcm so they say.. Compared to a none mcm 7800xt.. But that card cannot be a pcie spec gpu in that form as power use will be silly. If real it will be a server compute gpu under server grade cooling and power requirements.
7nm to 5nm is not that great power saving wise. So unless they are planning we all start using 1200w min psus for a single gpu system. We will see.. Also increases in core counts (cuda or amd cores) does not scale anywhere near stated in real world performance increase.. As we have seen from 2080ti to 3090.. It is a 50% increase with double the cuda count.
17 Aug 2009
You're not reading it properly.
The "7900xt" has mcm and 3x the cores of a current 6900xt and that is the comparison they are basing 2-2.5x faster on.
The "7800xt" has the same core count as a current 6900xt and that's what they are claiming 30-40% faster on.
9 Aug 2013
S. Wales
i see the psu requirements have leaked for next gen flagship cards:D
7 Dec 2010
Leeds
But the real world scaling doesn't work that way. I was still typing the above comment.. Read what I added. I know it has 3x the core count.. But the issue is real world scaling and the power use, unless they cap it to 350w-450w or that card left to its own devices will use 700w+ if not more. Yes amd have been good with cpus and controlling their power use but start add overclocks and increase voltage and power use limits and then watch the real power use they can pull. We are hitting scary power use now, even my dual 3090s are pulling 420w each and if I move the slider to allow them to use all the power allowed 470w then I see the system hit over 1200w at the wall for gaming and for my work that hammers the gpus and a 5950x at stock the system can hit 1350w and when spiking would be more.
This is my issue with such cards the real world scaling and power use and the heat produced.. If the 7900xt is a pcie gpu it will have a water cooler and will be capped for power use. Meaning you won't be getting anywhere near what it could do unless you stick it on exotic cooling. I don't believe that will be a pcie gaming card but a compute card for a server and the real 7900xt will be something smaller with sameish design with way less cores designed for gaming. I do have a feeling too amd may want to add more compute back into gaming cards because of miners and then they can target them as they lost out to miner sales this time to nvidia.
Also remember the 6900xt has almost 27 Billion transistors and to get to 3x the cores as they state that will be almost 81 Billion transistors and even on 5nm the power use is going to be insane.
The current best gpu is the A100 from Nvidia and that has 51 Billion transistors (with 6912 cuda cores and 432 tensor cores) and the SXM version is 400w and the pcie version is basically power capped to 250w. These are on TSMC 7nm.
https://www.nvidia.com/content/dam/en-zz/Solutions/Data-Center/a100/pdf/nvidia-a100-datasheet.pdf
Check this video:-
A good read here too regarding 7nm/5nm/3nm
https://www.extremetech.com/computing/272096-3nm-process-node
and here
https://semiengineering.com/power-and-performance-optimization-at-7-5-3nm/
and here
https://semiengineering.com/5nm-vs-3nm/
See the other issue is going to be cost to make these gpus on 5nm as 5nm is a lot more expensive to make devices on basically almost double the cost, unless they want us now to pay £2k+ for top end gaming cards, this of course is at the fake msrp and will really be higher ?
TSMC’s 5nm technology is 15% faster with 30% lower power than 7nm, so they say.
So a 6900xt is a 300w card, but a 7900xt is 3x this and on 5nm so 300w x 3 =900w and then with 5nm 30 percent lower power use = 30% of 900 is 270. 900 - 270 = 630. So best case it will be a 630w card for the 7900xt.
So do you want a 7900xt as they state that can use 630w ? That's why I keep saying something isn't adding up to that article being right.
Unless RDNA3 design does some strange things to get to these 3x core (shaders) counts on reduced transistor counts, but again I doubt that as that will mean the core counts are not true and only true in some work loads, like people questioned the Nvidia ampere core counts before and was shown they are true cores not a fake doubling. We just have to wait and see what the real gpu will be when out these rumours never seem to make sense and always turn out to be fake as we have seen many times before.
^.. worth a watch regarding Ampere cuda cores and explained pretty well by him, because people were questioning how nvidia doubled the cores so quickly on Ampere.
I do hope AMD do have something good to keep Nvidia honest next round, but I doubt it will be what they state in that article for the 7900xt.
6 Feb 2019
Check this video:-
and here
and here
It would be lower TDP surely.
even for server use 600w+ is not sustainable.
the 3x core count 7900xt would probably have its tdp lowered per chiplet and probably clock speeds too (so the 7800xt would have higher clock speeds than the 7900xt)
20 Nov 2020
This is stupid how can anyone believe the 7800xt will be 40% faster than the 6800xt but the 7900xt will be 200%-250% faster than the 6900xt? That's like making a 3090 and a 3060 with nothing between.
I am more interested in what MLID said, that AMD gave up on making cheaper cards and that 6600xt will be close to $400. If that is the case, then f...k them. I will never buy a stupid expensive card and i will never pay a lot for a card weaker than those inside the consoles.
17 Jun 2004
Eastbourne , East Sussex.
All rumours and BS from salty tech tubers who get paid for views. 6700XT is fighting with the 3070 and similar msrp price, so the 6600xt will be similar in msrp price and performance to the 3060
