local diff = {
    ["axisDiffs"] = {
        ["a2001cdnil"] = {
            ["name"] = "Pitch",
            ["removed"] = {
                [1] = {
                    ["key"] = "JOY_Y",
        ["a2002cdnil"] = {
            ["name"] = "Roll",
            ["removed"] = {
                [1] = {
                    ["key"] = "JOY_X",
        ["a2003cdnil"] = {
            ["name"] = "Rudder",
            ["removed"] = {
                [1] = {
                    ["key"] = "JOY_RZ",
        ["a2004cdnil"] = {
            ["changed"] = {
                [1] = {
                    ["filter"] = {
                        ["curvature"] = {
                            [1] = 0,
                        ["deadzone"] = 0.03,
                        ["invert"] = false,
                        ["saturationX"] = 0.85,
                        ["saturationY"] = 1,
                        ["slider"] = true,
                    ["key"] = "JOY_Z",
            ["name"] = "Thrust",
        ["a2033cdnil"] = {
            ["added"] = {
                [1] = {
                    ["filter"] = {
                        ["curvature"] = {
                            [1] = 0,
                        ["deadzone"] = 0.1,
                        ["invert"] = false,
                        ["saturationX"] = 1,
                        ["saturationY"] = 0.44,
                        ["slider"] = false,
                    ["key"] = "JOY_X",
            ["name"] = "TDC Slew Horizontal",
        ["a2034cdnil"] = {
            ["added"] = {
                [1] = {
                    ["filter"] = {
                        ["curvature"] = {
                            [1] = 0,
                        ["deadzone"] = 0.1,
                        ["invert"] = true,
                        ["saturationY"] = 0.45,
                        ["slider"] = false,
                    ["key"] = "JOY_Y",
            ["name"] = "TDC Slew Vertical",
    ["keyDiffs"] = {
        ["d101pnilunilcdnilvdnilvpnilvunil"] = {
            ["name"] = "Weapon Change",
            ["removed"] = {
                [1] = {
                    ["key"] = "JOY_BTN4",
        ["d102pnilunilcdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
                    ["key"] = "JOY_BTN6",
                    ["reformers"] = {
                        [1] = "JOY_BTN4",
            ["name"] = "Next Waypoint, Airfield Or Target",
        ["d103pnilunilcdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
                    ["key"] = "JOY_BTN11",
                    ["reformers"] = {
                        [1] = "JOY_BTN4",
            ["name"] = "Display Zoom In",
        ["d104pnilunilcdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
                    ["key"] = "JOY_BTN9",
                    ["reformers"] = {
                        [1] = "JOY_BTN4",
            ["name"] = "Display Zoom Out",
        ["d105pnilunilcdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
                    ["key"] = "JOY_BTN5",
                    ["reformers"] = {
                        [1] = "JOY_BTN4",
            ["name"] = "(1) Navigation Modes",
        ["d106pnilunilcdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
                    ["key"] = "JOY_BTN7",
            ["name"] = "(2) Beyond Visual Range Mode",
        ["d107pnilunilcdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
            ["name"] = "(3) Close Air Combat Vertical Scan Mode",
        ["d108pnilunilcdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
                    ["key"] = "JOY_BTN8",
            ["name"] = "(4) Close Air Combat Bore Mode",
        ["d109pnilunilcdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
            ["name"] = "(5) Close Air Combat HMD Helmet Mode",
        ["d111pnilunilcdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
                    ["reformers"] = {
                        [1] = "JOY_BTN4",
            ["name"] = "(7) Air-To-Ground Mode",
        ["d113pnilunilcdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
                    ["key"] = "JOY_BTN13",
            ["name"] = "Cannon",
            ["removed"] = {
                [1] = {
        ["d121pnilunilcdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
                    ["key"] = "JOY_BTN2",
                    ["reformers"] = {
                        [1] = "JOY_BTN4",
            ["name"] = "ASC Direct Control (Cobra)",
        ["d1315pnilunilcdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
                    ["reformers"] = {
                        [1] = "JOY_BTN4",
            ["name"] = "Previous Waypoint, Airfield Or Target",
        ["d177pnilunilcdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
                    ["key"] = "JOY_BTN_POV1_L",
            ["name"] = "Zoom normal",
        ["d285pnilunilcdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
                    ["key"] = "JOY_BTN15",
            ["name"] = "Radar RWS/TWS Mode Select",
        ["d357pnilunilcdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
                    ["key"] = "JOY_BTN3",
            ["name"] = "Countermeasures Flares Dispense",
        ["d358pnilunilcdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
                    ["reformers"] = {
                        [1] = "JOY_BTN4",
            ["name"] = "Countermeasures Chaff Dispense",
        ["d394pnilunilcdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
                    ["key"] = "JOY_BTN16",
            ["name"] = "Radar Pulse Repeat Frequency Select",
        ["d68pnilunilcdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
                    ["key"] = "JOY_BTN14",
                    ["reformers"] = {
                        [1] = "JOY_BTN4",
            ["name"] = "Landing Gear Up/Down",
        ["d72pnilunilcdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
            ["name"] = "Flaps Up/Down",
        ["d86pnilunilcdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
                    ["reformers"] = {
                        [1] = "JOY_BTN4",
            ["name"] = "Radar On/Off",
        ["d87pnilunilcdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
                    ["reformers"] = {
                        [1] = "JOY_BTN4",
            ["name"] = "Electro-Optical System On/Off",
        ["d957pnilu958cdnilvdnilvpnilvunil"] = {
            ["name"] = "Stick to Trimmer Control Mode",
            ["removed"] = {
                [1] = {
        ["d97pnilunilcdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
            ["name"] = "Trim Reset",
        ["dnilp139u230cdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
            ["name"] = "Scan Zone Left",
        ["dnilp140u230cdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
            ["name"] = "Scan Zone Right",
        ["dnilp141u230cdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
                    ["key"] = "JOY_BTN12",
            ["name"] = "Scan Zone Up",
        ["dnilp142u230cdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
                    ["key"] = "JOY_BTN10",
            ["name"] = "Scan Zone Down",
        ["dnilp32u214cdnilvdnilvpnilvunil"] = {
            ["name"] = "View Left slow",
            ["removed"] = {
                [1] = {
        ["dnilp34u214cdnilvdnilvpnilvunil"] = {
            ["name"] = "View Up slow",
            ["removed"] = {
                [1] = {
                    ["key"] = "JOY_BTN_POV1_U",
        ["dnilp35u214cdnilvdnilvpnilvunil"] = {
            ["name"] = "View Down slow",
            ["removed"] = {
                [1] = {
                    ["key"] = "JOY_BTN_POV1_D",
        ["dnilp39u289cdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
            ["name"] = "Zoom in slow",
        ["dnilp40u290cdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
            ["name"] = "Zoom out slow",
        ["dnilp412u414cdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
                    ["reformers"] = {
                        [1] = "JOY_BTN4",
            ["name"] = "Target Specified Size Increase",
        ["dnilp413u414cdnilvdnilvpnilvunil"] = {
            ["added"] = {
                [1] = {
                    ["reformers"] = {
                        [1] = "JOY_BTN4",
            ["name"] = "Target Specified Size Decrease",
return diff
