There is of coure another way to approach pricing:
Let's say AMD go all out and produce a 600mm² monster for the flagship.
- How much would it cost to make
- And, if wafers are still in short supply (which they will be...) how much profit could they make producing CPUs instead (this is mainly revelant for AMD)?
We can plug that into a wafer yield calculator (taking the 0.09 defect per cm which is something TSMC mentioned for 7nm - although that was a few years ago now):
https://caly-technologies.com/die-yield-calculator/
Now 600mm² is 24.5mm x 24.5mm, which gets us this:
For the die (ignoring testing, packaging, VRAM, board etc.), the only other consideration is how much wafers cost.
TSMC 7nm was meant to be about $10,000 per wafer but prices are rumourd to actually have gone up a bit.
6nm might be very similar rather than costing more as EVU might be super expensive but throughput and amount of masks is reduced.
5nm will probably be more, maybe $15,000 per wafer.
Anyway, $10k get us to $190 per die, $15k to around $280.
(This ignores that with redudancy not all dies with defects will be wasted, although against that not every good die is able to hit clocks/power targets.)
Those numbers aren't that bad actually: in theory that means a dual chiplet card might be doable for around $1,200 or so even with the $15k figure.
However, AMD at least have more profitable things they can do with wafers and that would be Zen3 or Zen4 CCDs or even APUs.
The current Zen CCD is 83.7mm² which means the wafer costs between $15 and $23 ($10k / $15k). Zen 4 might be a bit bigger, and of course the IO dies come on top of that.
In other words, CPUs have far higher margins.
We see that with Zen3 vs Navi21. A 5600X @ $300 versus a RX 6800 @ $579 using the $10k figure gives margins of 95% and 72% (with $15k per wafer it is 92% and 58%).
Hard to see how things will play out.
AMD seem to madly focused on margins ATM even at the cost of marketshare and mindshare. The design and mask costs are fixed, so once wafer are available it makes no sense to price too high, but what do we know?
Just an FYI
As of 12 months ago, TSMC was charging $16,986 per 5nm wafer. Since then they've increased their prices twice but by how much I don't know.
Various tech reporters have tried to dig out what the price changes were - the average from what I'm reading is an estimated 20% increase from pre to post covid.
So 16,986 + 20% after TSMC's increases = $20,383
So Redo your calculations using $20k or $21k per 5nm wafer as the cost and then you'll have some idea of RDNA3 prices and margins
. Business as usual...
