Probably not even 1fps difference.
I imagine the difference will be negligfble. In fact i imagine some of the non OC ones might even boost higher than the OC ones with that difference.
Yeah and you can always OC it yourself with afterburner if you want.I imagine the difference will be negligfble. In fact i imagine some of the non OC ones might even boost higher than the OC ones with that difference.
I preordered one of the inno3d ones and then watched thisnow im considering cancelling and preordering the zotac one instead
Bought a whole damn system! Just waiting for my monitor of choice to hit the UK marketYou bought a card?!!?![]()
Got lucky with a FE drop.Bought a whole damn system! Just waiting for my monitor of choice to hit the UK market
In my defence (to my wallet) the core components of my old system date back to 2012, so a completely new setup was long overdue.
And I paid RRP or less for everythingGot lucky with a FE drop.
I don't think I'll wait that long this time. 2012-2019 were "the stagnation years" on the CPU side at least.Yeah long overdue that one! Should last another eight, maybe by then component shortages will have disappeared, its nuts!
Hi there
Expecting stock to arrive next week and I shall also make some of the cards available for ore order again this afternoon.![]()
or does it have to be something magical like adamantium ore?
Adamantium isn't magical but nor does it exist in nature. Also....comics![]()
He had a few tunes out in the 80's though...
Hello everyone, I just preordered a Zotac RTX 3060ti but I was wondering if my computer will have a big problem with using that card. I currently have a Ryzen 2600 overclocked to 4.00GHz and only a CX550M Bronze corsair PSU. Ideally I don't want to upgrade just yet, would I be able to get away with these specs or would the 3060ti not have enough power / CPU give it an extreme bottleneck?
Edit: Is it also possible to see my queue position?
My mate runs a 3070ti with a ryzen 3600 at stock off a evga 550gm gold and it works fine, that combo seems decent enough, if anything the processor would be the bottleneck not the gpu especially at lower resolutions.
I am running a Ryzen 7 3700X,32GB 3600MHZ DDR4,a few SSDs and an RTX3060TI off a Corsair SF600 PSU. Power consumption under gaming load at the wall seems to be around 300W~310W at most.
The CPU is more likely to be a bottleneck in some games,but mostly at lower resolutions. However,as long as you have decent FPS,I would stick with what you have - any CPU can potentially cause some amount of bottlenecking.
thinking about, i wonder whether realistically there will be much difference between the coolers.
I am running a Ryzen 7 3700X... - any CPU can potentially cause some amount of bottlenecking.
Ok thank you so much guys, I have a 1080p monitor and run it at 144hz. Am I right in thinking the higher graphics setting I go for the more work the GPU has to do
