God knows when the 3080ti will be out
I managed to get hold of a Nvidia RTX 3090 in the endThis is probably too late but don't get screwed by NVIDIA at least until you've considered this:
So I still have random reboot issues though they tend to be when the cpu is not doing very much as when under stress no problems but if I'm just saying browsing through explorer system could just crash and random reboot would occur, anyone know where I can start to fix this? I have a 5950x. crucial ballistix 64gb (2x32gb). I have since when I set up the PC ran the RAM voltage at 1.37 just a tad higher than the default as I read elsewhere this helps. I have fmax enhancer (ASUS feature) switched off but PBO and core performance boost enabled. Would really appreicate it if others had the same issues and know how to go about fixing this?
I notice this tends to happen more when my system is set at high performance mode and windows isn't doing much than when system is say on balanced/power saver?
Thanks for this, I initially thought this solved my problem but since updating to 3702 and fmax enhancer has been switched off I still have the reboots, no idea why, very frustrating. Is it possibly something to do with cpu voltage but I have no idea how this works? It does seems to have sold my usb issues on the other handi had the very same issue with my board and a 5950x turns out there is a setting called Fmax Enhancer, by default its enabled but after reading up and disabling that option in the bios i now have no restarts at all, navigate to cpu settings regarding PBO and you should find the option near the top of the page, go ahead and disable it and enjoy no more random restarts![]()
Not a big fan of installing beta's I'll wait until it's final, glad it works for you thoughBios 3703 Beta installed. (Patch C / Improved system stability ..)
Running fine so far
depends if you run the cpu at stock settings and use auto voltage, if so that may be a issue as auto volts is far too high, you can get almost the same boost clocks but at a far lower voltage, my 5950x is left at stock settings with PBO enabled BUT i run a manual voltage for my cpu, instead of auto (1.45v) i set 1.25v max and my cpu still boosts to 5050mhz and settles back to a all core 4.5-4.6ghz in games, benchmarks will be a bit lower as the load is more on the cpu but i have had no issues, temps on my air cooler stay around the mid 70's and on occasion i can see low 80's but not very often, but thats still well within thermal specifications, only if the cpu hits over 105 degress will you get restarts or shutdowns, or it could be a psu issue but you'd have to undervolt your cpu first if you still get shudowns with a undervolt applied i'd have a look at your psu and make sure its up to the task, if not swap out for a 750-850w gold rated or more and you'll be good
Very interesting, can you tell me exactly what options you changed from the default ones in the bios to set this configuration ? With PBO enabled my 5950 is also constantly at 1.45v and 80–90 in game (with an NHD15). If PBO can work with a manual max voltage I would love to do it mate !!
the only main thing i have changed is voltage 1.45v for ryzen is far too high, so i back down to 1.25v and left core ratio at auto and enabled pbo, my cpu works at 5ghz for a few seconds then backs down to 4.6-4.7ghz under load to keep temps in check, i see max around 70 degrees at the settings above, if you want you can try 1.3v but that may be too much and you may overheat, i know my 5950x goes super nova above 1.28v so 1.3v or more is totally no go
and with that changed the voltage also go down when idle ?So I still have random reboot issues though they tend to be when the cpu is not doing very much as when under stress no problems but if I'm just saying browsing through explorer system could just crash and random reboot would occur, anyone know where I can start to fix this? I have a 5950x. crucial ballistix 64gb (2x32gb). I have since when I set up the PC ran the RAM voltage at 1.37 just a tad higher than the default as I read elsewhere this helps. I have fmax enhancer (ASUS feature) switched off but PBO and core performance boost enabled. Would really appreicate it if others had the same issues and know how to go about fixing this?
