So this SR vs DR keeps popping up, even seen that laptops are suffering!
And it makes me think.... is it worth me changing my SR 2x16GB Ballsitix sticks?
It seems 2x16GB Dual Rank sticks are hard to come by, and expensive!
This kit looks great: https://www.overclockers.co.uk/team...00c16-3600mhz-dual-channel-kit-my-002-8p.html
But at £300 is more than double what my Ballsitixs cost... and its OoS anyway.
So my question is.... would it be worth just buying another set of 2x16GB Crucial Ballistix for half the cost of the above set? Then either run 64GB if the new RAM is also SR. (Thus getting DR like speed?)
Or.... buy 4x 8GB of the Ballisitx at £77 each? Id get the non-RGBs at that point.
Interested to hear from anybody that DID make the change from SR to DR and what difference it really made? The place I can "see" the issue most is my CPU scores on 3DMark are like 2000 points~ lower than what people usually seem to get with a stock 5900x...
You are likely to get a better overclock using 2 sticks Vs 4 sticks, thus getting better performance boost compared to the move from SR to DR. Bottom line, 4 sticks generally not recommended.
