Have you tried anything to fix it? I should do a factory reset but I can’t be bothered.I have this with one of my Play 5's. It keeps changing its name to Default Speaker. Which is rather annoying.
I tried a factory reset and it made no difference. I've given up TBH.Have you tried anything to fix it? I should do a factory reset but I can’t be bothered.
If you're happy with the bass you're getting from the Beam then I can't see any reason why you wouldn't be happy with the bass from the Arc.
This.The sub does make a huge difference to the Arc.
This.
I found the Arc a bit lacking without the sub tbh.
Arc + Sub + Play:1 rears. You know you want to.Would you go Beam + Sub or Arc no sub? Keeping in mind I have 2 x Play:1 rears and don't need big bass.
Beam + Sub personally.Would you go Beam + Sub or Arc no sub? Keeping in mind I have 2 x Play:1 rears and don't need big bass.
Just think of the reactions in the images of things I've purchased thread.Ha you guys are a bad influence. Will think on it.
I have the 65CX and an Arc, sits beautifulThanks, ordered the Arc as I find the Beam a little lacking and also looks stupid under my 65 CX
Back ordered until the end of August boo...
Paid £679.15 with student discount.
Under it![]()
At least there's no trainers now.I'll get buried quickly by images of bike parts and discussions about people's poor choice of purchases.
I've had it where audio completely drops and I have to restart the TV. It seems to affect Apple TV audio and I think Sky has been okay. I wonder if it's also the HDMI cable but then I guess that Sky would be fine.A little while back now, I was reporting my Sonos Arc was having an issue where the audio kept dropping out. Ended up being the HDMI cable being naff which Sonos supply with the Arc.
Yea the Beam currently looks silly under the 65CX.
