I have seen several comments where people state a 90 degree fitting is very bad for the flow in a water loop, and that these should be minimised as far as is possible. Is this actually a concern?
my next loop is almost definitely going to be soft tube. But, all rigid tube design are mostly based around 90 degree turns.
So, what’s the consensus? 90 degrees = bad? Or not an issue? Thanks
