Have you tried to update the BIOS?
Anyways, if a 65-watt Intel CPU matches the 105-watt AMD CPU, then very hard times are coming for AMD.
AMD might be screwed.
I can do this and yes it definitely helps - but the cpu is then slower than the 3950x it replaced in anything that's multithreaded and there is my conundrum, why did I buy the 5950x if it's slower than the 3950x which was 100% stable with PBO and heavily overclocked memory
The 5950X is faster than the 3950X across the board, 10 to 25% faster. https://www.techspot.com/review/2131-amd-ryzen-5950x/
Look, i'm not being funny with you but you're telling me a Zen 3 CPU is slower than a Zen 2 CPU with the same number of cores and you think its a problem with the product rather than with you or your system, what in your mind do you think i think about that?
