Hi thanks for the answers.
@LuckyBenski my post is now edited, sorry.
I have found out that my board has a 12v 4 pin output only, which is a shame.
I already have one of these,
https://www.overclockers.co.uk/ek-water-blocks-ek-d-rgb-6-way-splitter-cable-wc-9vx-ek.html, but am not using as the 14 EK fans & the pump all daisy chain quite happily.
I bought an EK loop connect when building my system, but it has problems, & is to be RMA'd, I intend to get the new version when its released as I have the level sensor & flow sensor, but will have no controller, just the onboard PWM sockets.
so I'm looking for something to sync both the corsair LED's & the EK fan + pump LED's to my motherboard (ROG Rampage V Edition 10, with EK monoblock) & Ram's (G.Skill Trident Z's) via armoury crate if its possible.
I have got a Corsair commander pro box, the obsidian 1000d comes with one, I just would prefer to only be using one lighting effect controller, & I like the effects that you can create with armoury crate.
			Asus will sync all your rgb devices to look exactly the same whether you use a splitter or not
That is exactly what I'm wanting.
