- 10 Jan 2004
- Poland
Hi all, can anyone tell me if they've fitted a Arctic Freezer II 280mm in the P600?
Have indeed, in the top of the case, lots of room
Excellent thank you! I was going to go for the Lian Li O11, but including purchasing the case fans the cost is almost double and on top of that the mods that will be required such as modded cables to ensure the graphics card power connector isn't pushing against the glass is just adding to the cost.Have indeed, in the top of the case, lots of room![]()
Is there much difference between the P600 and P500A?
Thanks! I purchased it yesterday and looking forward to building in it soon.
If you have one, can you tell me how good the case fans are that come with it? The room it will be based in is very warm during the summer and I need fans that will push through a lot of air flow.
The fans that come with it are no name Phanteks but they are pretty good, move a lot of air but arent super quiet. I replaced them with Artic P14s for the great static pressure to overcome the mesh and dust filter at the front, they do a fantastic job keeping everything cool![]()
I didn't take the chance this time, I just bought 3 Noctua 2000rpm industrial fans. I have 2 of these fans already which I'll be putting on my Arctic Freezer II AIO, 3 will go on the front and I'll keep the case fan for exhaust fan at the back and I also have a 120mm 2000rpm Noctua Industrial fan which I'll stick at the top beside the AIO.
Hopefully this is a good configuration!
Too late I already purchased them and they'll be coming tomorrow! Genuinely excited even though it's just a new case lol.That config will be great BUT i do urge you to try the P14s on the AIO first, they are crazy good fans and ridiculously quiet even at full chat, there's a reason i have these fans all over my case![]()
Looking to buy the artic freezer 2 will it fit in the top of my evolv x.
Thanks
Still my all time favourite case the P600s, would get another in a flash
Thanks mateThe 280 version fits fine in my P600S so it should be grand![]()
