- 21 Jun 2006
Is everyong using a custom curve or just alterting core voltage?
My original curve -
And after reading the sucess of lower voltages I will start nudging the lower nodes up -
What do your curves look like?
I forgot that I also have a +450 on the memory. I'll need to prove to myself again that it does as intended.
You shouldn't overclock memory whilst trying to find a stable core.
Do core only. Find a stable core. Then try clocking the ram.
You may find one makes an impact on the other. As an example. Your plus 400 on the memory could be making your core need more volts to be stable.
Plus memory makes such a small difference it's best leaving it stock anyway until you have your core sorted then see if it's even worthwhile.
