AMD R5 3600 dying again?
OP
26 Jul 2011
West Yorkshire
Had 1 game, it jittered several times. I checked HWInfo64 and the RAM hasn't moved from 1066.5MHz, it's rated for 3600! (1800 as I presume HWInfo64 is not giving it doubled)
18 Oct 2002
Leicestershire
When you say its rated, if that's on an XMP profile, not everything will like it, as in my previous post, my RAM was XMP rated but when I ran it using XMP the machine would lock up, letting the BIOS just AUTO it solved the problem. Check your board manual and make sure that the RAM is in the right slots as well, you might find the board doesn't support XMP over more than 2 modules and they need to be in the right holes..
18 Oct 2002
Manchester
I had some 3600mhz ram issues on my B450 tomahawk max when I first got it. For me, updating to newer BIOS versions and only using XMP profile 2 on my ram kit fixed it.
Even now, XMP profile 1 will cause the PC to freeze, but profile 2 is perfectly stable, not sure if its a corrupt XMP profiler, if such a thing is possible, or if the mobo is not changing some setting correctly.
17 Aug 2009
Hello, I just got a new cpu on warranty and after 4 days it's done the same thing that finished off the other one : computer freezes during gaming and both of my screens turn off so I had to hard reset it.
After a quick search : could it be the PSU? It's an XPG CORE Reactor 750W gold rated. It's only half a year old. I had no problems with the Corsair 600w gold rated that was in it for probably 3 years at least (but I put that in a second pc I was building for us).
Motherboard is an MSI B450 Tomahawk (the old one that I had to update the BIOS to accept the 3600 cpu).
pc is watercooled so cpu doesn't go over 65*C
I had it slightly undervolted via offset on the old broke one.
It's now fixed under 1.3volts (still going down 1 step at a time to see how low it will go) @ 4.1GHz.
do you have lights on your keyboard/mouse/monitor do all of them turn of when the computer freezes or do they stay on ?
OP
26 Jul 2011
West Yorkshire
I ran the windows memtest and it was fine.
Im pretty sure it's just 3600 rated and not XMP but I'll check that, I haven't used XMP on it but could try it to see if it helps.
The sticks are in the correct slots.
6 Jun 2008
Finland
Your wrong again, current draw can be limited in bios.
Unlike common for Intel boards, every AM4 board BIOS sets hard current and power limits to maximums defined by AMD for that CPU.
And that assuming CPU temperature is well under control.
That's very different from Intel side on which BIOS usually allows (likely with Intel's blessing) continuous drawing up to what Intel advertises as short term peak numbers.
OP
26 Jul 2011
West Yorkshire
The Ram I have is Geil Orion AMD 3600MHz 2x8GB. It's XMP2.0 capable. I assume it should run at 3600MHz though without XMP or extra voltage etc. as I guess it's been binned for that speed?
Is that how it works?
18 Oct 2002
Manchester
Possibly not, I think it needs at least 1.35v at least looking at the specs from http://www.geil.com.tw/product/?id=51
Presumably if you don't use XMP and simply set the frequency to 3600mhz, it might be trying to run at 1.2v? which probably won't work, or at least will be extremely unstable. I'd say either use the XMP profile, or set DDR voltage to 1.35v
OP
26 Jul 2011
West Yorkshire
If I remember correctly in the Bios the ram was on 1.364v.
I've downloaded the spec sheet from their website and I'm not sure the ram is even supported on my motherboard yet it's for ryzen 5 3600s.
GAOG416GB3600C18BDC
OP
26 Jul 2011
West Yorkshire
Looking at the MSI B450 tomahawk web page, it only supports up to 3466MHz RAM via A-XMP anyway...
  • Supports 1866/ 2133/ 2400/ 2667Mhz (by JEDEC)
  • Supports 2667/ 2800/ 2933/ 3000/ 3066/ 3200/ 3466 MHz (by A-XMP OC MODE)
Slight oversight on my part
15 Oct 2019
Uk
I wouldn't worry to much about the what the board support pages says as it's likely not been updated from Zen+.
I have the tomahawk max which is the same board expect the larger bios chip and I've had ram running at 3800mhz 1-1 with both the ryzen 3600 and 5800X, I've also had the ram running at 4400mhz with a 2-1 fclk.
OP
26 Jul 2011
West Yorkshire
Oh wow nice, ok then thanks.
I've had a quick test (gaming) of the RAM on the only XMP profile I appear to have and it seemed ok; will be testing it more this evening to see if I get a freeze.
OP
26 Jul 2011
West Yorkshire
Just had a freeze, playing Overwatch because Apex not connecting; Numlock didn't work but laser and lights on mouse remained on. No signs of laggy performance in game or anything, it just froze.
