Yes, not sure how accurate CPU Monkey is but they have 5900HX scoring 13,875 in Cinebench R23.
https://www.cpu-monkey.com/en/compare_cpu-amd_ryzen_9_5900hx-vs-apple_m1
they also have the 5800U:
What is more impressive for the M1 is the single core results vs the 5800U:
Far more impressive than the CPU scores, are the M1's GPU scores.
In the AT review:
https://www.anandtech.com/show/16252/mac-mini-apple-m1-tested/3
The 5800U has a configurable TDP of 10 to 25 Watts, i think we have to assume that this score is at 25 Watts, which is extremely impressive, i think it also has to be said that Zen 3 has much better performance per watt at these lower power levels than it does at higher power levels, its at its most efficient at around 20 to 30 Watts.
A 5800X scores around 50% higher but that's with 400% higher power, that should tell you just how much the efficiency drops off at high power targets.
It is what it is and at low power level its damned impressive.
The M1 Mac Mini scores just short of 8,000, the Mac Mini draws 39 Watts, the CPU alone, i would take a guess at 20 Watts. https://en.wikipedia.org/wiki/Apple_M1
So
5800U, 8 cores: 11,203 at 25 Watts.
Apple M1, 8 cores: 7,833 at 20 Watts.
20 Watts / 25 Watts = 1.25, 25% lower power to the M1
11,203 / 7,833 = 1.43, 43% higher performance to the 5800U.
In this configuration Zen 3 has about 15% better performance per Watt.
Its a bit meaningless, but i think one thing we can be sure of is the Apple M1 and Zen 3 are extremely efficient CPU's, at least when you compare them to team blue.
The thing that really does need to be said tho is that the Apple M1 is on TSMC 5nm, Zen 3 is on TSMC 7nm.
