Recommended Fan Controller: 3x 360 rads
I dont think anyone is using 40 fans and 2 pumps so aquaero is surely fine
Qute video. Keep in mind that's 4x sets of 10 fans, so 4 temp to PWM signal curves. QUADRO and OCTO can be added for more fan curves.
I'm convinced aquacomputer makes the best monitor and control hardware and software on the market!
If anyone knows of similar or better products, please let us know what they are.
The only downside i know of for AC software.. (unless i've been doing it wrong for the past few years) is that their software is only licensed for a year.. so if you want to update the software, you need to pay a yearly subscription of about a tenner. Can't remember about firmware updates though
You can dl version you have on old licence after it expires. You just can't dl versions of software newer than what your licence covered. Hope that makes sense.
ahh makes sense.. so i need to make sure mine doesn't auto update then.
I remember one of my rigs updated itself and AC wouldn't start as it showed as license expired... i guess what i should have done was to remove the current version of AC, and downgrade to a lower version... instead, i just pruchased a new license and updated the software
