must be some skill you got there applying thermal paste to cpu ending up getting it on gpu contacts lol![]()
Haha yep mad skill
A lesson learnt..
I've seen a CPU work fine for everything before with a dGPU, then when it come to using the iGPU it just didn't work, was a single bent pin in the socket..
Things are so bloody tiny these days you have to be very careful building stuff, personally, I always put the CPU into the board and goop and heatsink it before it goes in the case just so you have everything flat when building up and it just gives you room to move things around and test before you case up.
Aye lesson learnt : rather than just wipe it with a paper towel, nail polish remover is a substitute to isopropyl alcahol. If only I did that when I took the gpu apart to clean all the goop out of the waterblock I'd of avoided 2 problems.
