Caporegime
- 9 Nov 2009
- Planet Earth
Just remaster the scenes to upscale and clean them up, re-render the space scenes at a higher resolution, and be done.
I dunno, i mean i like the old show and rewatched a lot recently. If they reboot with a clean slate and dont repeat set characters or story arcs and is fresh with new races maybe and b5 is different enough. It could be fun to watch. The cast would have to be good tho and the cgi id hope has a good budget if its to beat the crazy good cgi fights if a little non-hd looking from the past shows.
Please don't. Everything they reboot, they ruin. They are never going to replace the wonderful actors they had. Just remaster the scenes to upscale and clean them up, re-render the space scenes at a higher resolution, and be done.
the current HBO MAX 4:3 ratio partial HD remaster, where the sharping, polish here and there is the best we going to get. As the facility where all the b5 raw footage, cgi data, model etc which was used to create b5 had a fire and sadly nearly all b5 related material was lost, hence no upscale / HD Master of the pilot movie "the gathering" as there nothing to work with to do so. so in order to do a true remaster they would have to recreate all cgi data and model from scratch. that a lot of time and money that they are unwilling to pay.
CW are paying.
