The Radeon RX 6800 (XT) Owners Thread.
Caporegime
12 Jul 2007
United Kingdom
Psu won’t be a problem as I’m using the same watts psu.
make sure you ain’t daisy changing the cables going into the card.
If your using a 10 bit panel, change it to 8bit with free sync on.
change your min and max clock speed, for example 2400max/2300min. Has to be at least 100mhz difference.
Maldonado, make sure you’ve picked the right pci express gen speed in the motherboard bios as that has caused issues before if your using a riser cable
Enabling 10 bit pixel format under the display tab is fine and needed if you have a 10 bit display.
The 10 bit option under global graphics does not need to be enabled though unless you are using something like photoshop for 10 bit.
26 Dec 2005
Paisley
Ill try the 8bit thing, ive done all the other stuff. Thanks.
8bit made no difference.
Just ran Borderlands 3 benchmark, got 98 on high at 1440p.
Rest of the PC is 3600XT, 3600 corsair vengeance pro cas 14, 2 x m.2 drives.
Reason i think its power, i had similar problems with this power supply with a 3080 before, i have a tiny bit of coil whine with this card and you can hear the card stutter when it stutters on screen.
Ive got a 850w platinum coming today to test out, if it doesnt fix it ill just fire it back.
24 Aug 2009
I’ve seen that free sync doesn’t work properly when using 10 bit panels?
26 Dec 2005
Paisley
Right, i think ive got it fixed - if i undervolt the card even slightly it wigs out. Not sure because its the asus water cooled one it has a higher power limit than my merc 319 i had before but that seems to have done the trick, thanks for the advice guys.
4 Jan 2005
I am using 10 bit color depth with ycbcr 4:4:4 at 4k120 and freesync premium on a Q70A display and a 6800xt and had no problems at all there either. Both the TV and the PC shows freesync as working. If it was an issue before, it must've been fixed driver-side fairly recently.
Man of Honour
OP
21 May 2012
Dalek flagship
Welcome and on TROH.:)
The Roll of Honour.
Date 08/09/2021, Make Asus TUF 6800 XT, KNiVES, Link
Date 31/07/2021, Make Asus TUF 6800 XT, Cyrus Leander, Link
Date 28/07/2021, Make Asus Strix LC 6800 XT, martian1, Link
Date 25/07/2021, Make Asus TUF 6800 XT, Nghtmare, Link
Date 19/07/2021, Make PowerColor Red Devil 6800 XT, AmDaMan, Link
Date 17/07/2021, Make MSI Gaming X Trio 6800, Quixote, Link
Date 07/07/2021, Make AMD Reference 6800, LtMatt, Link
Date 23/04/2021, Make Sapphire Nitro+ 6800 XT, iniaes, Link
Date 26/03/2021, Make PowerColor Red Dragon 6800 XT, Stanners, Link
Date 24/03/2021, Make XFX Merc 319 6800 XT, rare, Link
Date 24/03/2021, Make ASRock Taichi 6800 XT, Space Monkey, Link
Date 23/03/2021, Make Sapphire Nitro+ 6800 XT, Legionaire68, Link
Date 22/03/2021, Make XFX Merc 319 6800 XT, MANFACE, Link
Date 13/03/2021, Make AMD Reference 6800, t2na, Link
Date 09/03/2021, Make MSI Gaming X Trio 6800 XT, Buffalo2102, Link
Date 09/03/2021, Make Sapphire Nitro+ 6800 XT, Vince, Link
Date 08/03/2021, Make XFX QICK 319 6800, oweneades, Link
Date 24/02/2021, Make Gigabyte Aorus Master 6800 XT, Grandmaster Fap!, Link
Date 12/02/2021, Make Sapphire Nitro+ 6800 XT, Kirby Wurm, Link
Date 12/02/2021, Make AMD Reference 6800, old gamer, Link
Date 12/02/2021, Make Sapphire Nitro+ 6800 XT, IainTKD, Link
Date 11/02/2021, Make Sapphire Nitro+ 6800 XT, T1Cybernetic, Link
Date 11/02/2021, Make Sapphire Nitro+ 6800 XT, Johnny Silverhand, Link
Date 10/02/2021, Make Sapphire Nitro+ 6800 XT, PzR Slim, Link
Date 10/02/2021, Make AMD Reference 6800, Harlequin, Link
Date 08/02/2021, Make Sapphire Nitro+ 6800 XT, im4gine3, Link
Date 08/02/2021, Make Sapphire Nitro+ 6800 XT, mattyc123, Link
Date 06/02/2021, Make Sapphire Nitro+ 6800, leemk, Link
Date 04/02/2021, Make AMD Reference 6800, Mike_P, Link
Date 02/02/2021, Make Sapphire Nitro+ 6800 XT, Scoobynuts, Link
Date 02/02/2021, Make Sapphire Pulse 6800, Aztec2Step, Link
Date 01/02/2021, Make Sapphire Nitro+ 6800 XT, atomixers, Link
Date 01/02/2021, Make Gigabyte Gaming 6800 XT, philo-sofa, Link
Date 01/02/2021, Make Sapphire Nitro+ 6800 XT, Vegeta, Link
Date 30/01/2021, Make Sapphire Nitro+ 6800 XT, Jimbo, Link
Date 29/01/2021, Make Sapphire Nitro+ 6800, Johnny Silverhand, Link
Date 29/01/2021, Make PowerColor Red Devil 6800 XT, roger_37, Link
Date 27/01/2021, Make Sapphire Nitro+ 6800 XT, Unreal22, Link
Date 27/01/2021, Make Sapphire Nitro+ 6800 XT, Davinnicus, Link
Date 27/01/2021, Make PowerColor Red Devil 6800 XT, Satchfanuk, Link
Date 27/01/2021, Make MSI Gaming X Trio 6800, welshrat, Link
Date 26/01/2021, Make AMD Reference 6800, Figo, Link
Date 21/01/2021, Make XFX Merc 319 6800 XT, w00dy85, Link
Date 13/01/2021, Make PowerColor Red Devil 6800 XT, Vimes, Link
Date 13/01/2021, Make PowerColor Red Devil 6800 XT, bimbleuk, Link
Date 11/01/2021, Make AMD Reference 6800 XT, Shilz, Link
Date 08/01/2021, Make AMD Reference 6800, faceman123, Link
Date 04/01/2021, Make Sapphire Nitro+ 6800 XT, KentMan, Link
Date 04/01/2021, Make Sapphire Nitro+ 6800 XT, sparkymark75, Link
Date 23/12/2020, Make AMD Reference 6800, Metalface Mark, Link
Date 23/12/2020, Make PowerColor Fighter 6800, MattBoxer, Link
Date 17/12/2020, Make AMD Reference 6800 XT, smellster, Link
Date 17/12/2020, Make XFX Merc 319 6800 XT, Sad Panda, Link
Date 16/12/2020, Make Sapphire Nitro+ 6800 XT, MaDMaX**, Link
Date 16/12/2020, Make XFX Merc 319 6800 XT, Apache14, Link
Date 14/12/2020, Make AMD Reference 6800 XT, Kangaxx, Link
Date 13/12/2020, Make AMD Reference 6800, Rezident, Link
Date 12/12/2020, Make AMD Reference 6800, Bonjour, Link
Date 11/12/2020, Make AMD Reference 6800, gettothechopper, Link
Date 11/12/2020, Make AMD Reference 6800, silk300, Link
Date 10/12/2020, Make AMD Reference 6800, rolypolyman, Link
Date 10/12/2020, Make AMD Reference 6800, Haggisman, Link
Date 07/12/2020, Make AMD Reference 6800, DynamicOCUK, Link
Date 05/12/2020, Make AMD Reference 6800, Jumper118, Link
Date 27/11/2020, Make AMD Reference 6800, TripleT, Link
Date 27/11/2020, Make AMD Reference 6800, Phat-Bud, Link
Date 27/11/2020, Make AMD Reference 6800, Shuflie, Link
Date 27/11/2020, Make AMD Reference 6800, Heofz, Link
Date 27/11/2020, Make AMD Reference 6800, Kill_Phil, Link
Date 26/11/2020, Make AMD Reference 6800 XT, LtMatt, Link
Date 25/11/2020, Make AMD Reference 6800 XT, Glanza, Link
Date 24/11/2020, Make AMD Reference 6800, sweenEire, Link
Date 24/11/2020, Make AMD Reference 6800 XT, BogEyes, Link
Date 23/11/2020, Make AMD Reference 6800, Milo01, Link
Date 23/11/2020, Make AMD Reference 6800, Sgt_Pepper, Link
Date 23/11/2020, Make AMD Reference 6800, BigJack, Link
Date 22/11/2020, Make AMD Reference 6800, phawk, Link
Date 22/11/2020, Make AMD Reference 6800, AfrogoatST, Link
Date 22/11/2020, Make AMD Reference 6800 XT, JCLDJB, Link
Date 21/11/2020, Make AMD Reference 6800, Darren_uk, Link
Date 20/11/2020, Make AMD Reference 6800 XT, dante6491, Link
Date 19/11/2020, Make AMD Reference 6800 XT, Rastan007, Link
Date 19/11/2020, Make AMD Reference 6800 XT, Gears, Link
Date 19/11/2020, Make AMD Reference 6800 XT, Chrisola, Link
Date 19/11/2020, Make AMD Reference 6800 XT, montymint, Link
Date 19/11/2020, Make AMD Reference 6800 XT, almoststew1990, Link
Date 19/11/2020, Make AMD Reference 6800, lovelyhead, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your Radeon RX 6800 (XT).
29 Oct 2002
Has to be a local system issue. Have you tried a selective start-up in case you have any background apps causing issues?
To reboot in a selective startup:
Press WINDOWS-R on the keyboard to bring up the Run window, enter MSCONFIG and click OK.
Under the General tab, click "Normal startup" if it is not selected already.
Under the Services tab, put a check on "Hide All Microsoft Services" and then click "Disable All."
Under the Startup tab, these will still be disabled in Windows 10 in the Task Manager.
Click OK on the MSCONFIG window, and then click Restart when prompted.
Sounds like the issues I was having with my 6900XT. Can't remember what I did to resolve it now .
30 Oct 2020
Hi guys, did someone try the open beta of new world with a 6800xt? My gpu usage is terribly low in crowded areas and the result is having horrible fps drop. I'm playing at 1440p max settings, paired with a 9900k (never above 45% in demanding towns) and 16gb of ram 3600mhz.
7 Oct 2015
Can anyone tell me what the thickness is of the stock thermal pads for the Sapphire 6800xt Nitro+?
Planning on selling my card with the waterblock but if there is no interest, will try to sell with the stock cooler.. but can't remember the thickness needed.
10 Sep 2006
pretty sure they are 1mm , guessing the old pads fell apart when you removed the stock cooler.
Permabanned
20 Jan 2021
Glad I sold my 6800XT, coil whine was mental and the card was overpriced but looked great and had good thermals
Caporegime
18 Oct 2002
Running latest optimised driver for New World? 21.9.2 iirc
28 Sep 2021
Scotland
I've just been reading the grim news on the 3080 thread however it did seem to imply that the stock situation for the 6800XT is relatively good.
I just purchased a 6800XT on Sunday the 26th, was one available at the time of purchase however I just got a message informing me that the item I purchased is out of stock, awaiting more stock from the supplier.
I was just hoping anyone who made a recent purchase of this card could give me an idea of whether I'll be waiting weeks or months?
I would prefer not to have to refund but the prospect of being out of pocket with no product for a significant period of time is not one I would relish.
Edit: a word
3 Oct 2013
Edit: a word
Is this from OCUK ?
If so post in the CS section they're pretty good at getting back to you / sorted.
