- 3 Feb 2009
For me, there's not much that would justify £27 for a fan...I assume the Lian Li UNI fans are worth it?
What's a good recommended drainage fittings for hooking up a hose to the front distro plate? Since I'm all EK fittings.
Getting real close now to start work on the pipe measurements. What a task this has been so far. Will have to install the fittings down the back of the GPU for the limited space I have. It's the last part to complete.
It's worse than a very hard jigsaw.![]()
You use a fitting on the end of the pipe, I use some soft clear pipe and a soft tube compression fitting. You unscrew the cap and screw in the fitting and then quarter turn the drain port body and pull it towards you which then opens the port, I have one also.How does that work for hooking up a hose to it?
