In terms of the radios, I believe most models are global and set up the usable channels and power according to which country you select when setting them up.
But, if the router is one with an external power supply of the sort where the transformer and plug are integrated (aka a "wall wart"), the 2-pin version will be a pain. You can use an adapter, of course, but the whole then tends to get quite wobbly.
