Deleted User 298457
Deleted User 298457
To be honest I thought he was taking pictures of the cabinet in the shop he bought itfrom!That's a fine looking living room you have there!
I didn't know Habitat sold arcade cabinets in kit form! Might pop in.To be honest I thought he was taking pictures of the cabinet in the shop he bought itfrom!
I think these are the ones that require special heads and not the usual OralB ones? It's the only reason I stuck with a more standard model of theirs.
And yes on the app - used it twice! It requires location enabled to function on Android...
This is Carly (iOS and Android) - Really nice app that does more than just diagnostics. Note, you don't need the Carly dongle to use it, if you already have an OBD2 dongle that's wired or wireless then it will still work but check what dongle you have as not all wireless ones offer coding features whilst the wired ones do.
That'll most likely be because any application targeting Android 11 or lower (pretty much every app considering 12 hasn't been released yet), ACCESS_FINE_LOCATION permission must be declared in the Manifest if Bluetooth is being used, which the app will use considering the connection to the toothbrush is via Bluetooth. I.e. they're most likely not getting your location, it's more a technical oversight of the permission system on Android.
Looks like they're changing this with Android 12 and later:
https://developer.android.com/guide...uetooth/permissions#assert-never-for-location
Everyone is allowed to buy one electric toothbrush in their life. No justification, no finger pointing.I bought that after a strong recommendation from my dentist that it cleans better than other toothbrushes. It certainly felt a lot stronger than my current toothbrush. But after spending hours researching I couldn't find any evidence of it, other than it simply connecting to an app which I wouldn't use anyway. I also realised my current toothbrush was quite old and would have lost some power so naturally any new toothbrush would feel better. So I sent it back before opening it. Let me know how you get on with it though.
Great stuff thanks @mrk tried a few freebies which connected to my Carista dongle but weren't the best of apps.
You do it twice though, and it's open season.
Nah go for it and save yourself the cash!Thanks
Got someone lined up to come and build it in the next few weeks
New boots* for when I have to stop wearing shorts due to the weather
*Not trainers.
