Hi all, I want to put a shower where the previous units where and a small bathtub adjacent.
Upon removing the wall I realise it's relatively smoothly plastered. I believe it's dot and dab onto plasterboard.
Is it possible to tile straight onto this wall without taking it all off / back to brick? Is it worthwhile applying waterproof tanking straight onto this back plastered wall?
Would I be better knocking the plastered wall back to brick. Then applying a tanking compound?
I will be having the pipework seperately installed by a plumber as part of a larger package of works (installing radiators/replacing all microbore pipework). The radiator will be moved from its current position to adjacent the door.
I will also be seperately getting a tiler in and walls that aren't tiled plastered by a plasterer.
Basically main "DIY" element is replacing flooring and sorting drainage for bath and shower and also fitting units.
Would appreciate any articles people can link!
Can see the flooring is a little knackered! I need to fit a shower above this...
That's a bit chaotic, don't see any reason why any of those cant be under the floor.
I fixed it by raking the old cracked grouting out and putting fresh grout in. But I'm going to have to keep a close eye on it now.
