- 8 Jan 2011
- London, UK
Hi all, as per thread title: what’s the practical difference I might see running a 3xxx GPU on a 4th gen PCIe slot at x16 speed, vs running it at x8 speed? Thanks!
Ok thanks mate that’s very useful. The reason for asking is that I’m about to run an ASUS Strix z590-e motherboard with Intel 11900k, and this motherboard has two gen 4 PCIe slots for NVMe, but, if I use both slots then I can’t run the GPU at PCIe 4 x16 speed, it’ll have to be reduced to x8 as it apparently shares bandwidth with the second NVMe.
Which is a bit odd, unless of course ASUS were not worried about the hit to the GPU performance, which from the article would appear to be negligible. Cheers![]()
If you want PCIe v4 for everything, you need Ryzen and X570 board.Which is a bit odd, unless of course ASUS were not worried about the hit to the GPU performance, which from the article would appear to be negligible. Cheers![]()
Hi all, as per thread title: what’s the practical difference I might see running a 3xxx GPU on a 4th gen PCIe slot at x16 speed, vs running it at x8 speed? Thanks!![]()
