My car doesn't have keyless entry, but does have keyless start. I assumed I wouldn't need a faraday pouch, am I right or wrong?
What car is it?
I know my car (New Octavia) has sleep keys but you can also just turn the keyless entry off.
I just turned it off as I've had it on a car before and don't really see the point of it really, pressing a button on the key fob is no hardship.
If you want to test for sleepy keys, put the key on the floor near the car such that keyless entry works, then lock the car and don't touch the key for a couple of minutes. Then try opening the door on the car without touching the key, if it is a sleepy key the car won't unlock.It's a Peugeot 3008
It's a Peugeot 3008
I have a keyless entry car. Always keep keys in my handbag which is kept in a room on the other side of the flat to my car space. Can’t open car with handbag there.
I was more thinking if they could copy the signal that allows you to keyless start, if they can get in the car somehow, then they can start the car?Correct, you don't need one as you need to physically press the fob to open the car.
I assume the signal is much weaker for keyless start. I have keyless start and if you step out of the car it complains it lost the key. Hence they shouldn't be able to relay the signal; unless you have the key right next to your door/external wall.I was more thinking if they could copy the signal that allows you to keyless start, if they can get in the car somehow, then they can start the car?
