Google Pixel 6/6 Pro
6 Jan 2013
Rollergirl
I'm really sorry to be requesting a spoon feed here, but I've received a £50 voucher for Amazon and want to pick up a wireless charger for my P6. I'm finding the tech a bit confusing in terms of am I buying the best/latest.
Could some kind person link me to the best buy (I can go over the £50 voucher budget if required).
TIA :)
18 Jan 2015
Consett
Spigen Liquid Air and Spigen Align Master Screen protectors ready to go.
eDCy5Cs
eDCy5Cs
Can you open them up and give us some pics please? i want to order the same.
15 Nov 2007
Enfield
Worst fitting case I have ever seen. The first one arrived for my pixel 5 and would not go around edges and when forced would pop off, email to customer service ended up with a replacement "hand checked" coming my way.. replacement didn't fit well either and at that point I gave up and threw it in the box of cases I'll never use/buy again. So my personal experience? Avoid.
Hmmmmm ok that's not good. Thanks for the heads-up.
12 Mar 2008
West sussex
TIA :)
Any "qi" charger will work. If you want fast charge then get one that's able to push that..
6 Jan 2013
Rollergirl
Cool, I'll go for this combo:
Quick Charge 3.0, Anker 18W 3Amp USB Wall Charger (Quick Charge 2.0 Compatible) Powerport+ 1 for Galaxy S10/S9/S8/Edge/Plus, Note 8/7, LG G4, HTC One A9/M9, Nexus 9, iPhone, iPad and More https://www.amazon.co.uk/dp/B017VXA...abc_FVJJA0PSCR9H1R4SCKC7?_encoding=UTF8&psc=1
Anker Wireless Charger, PowerWave Pad Qi-Certified 10W Max for iPhone 12, 12 Mini, 12 Pro Max, SE 2020, 11, 11 Pro, AirPods, Galaxy S20 (No AC Adapter, Not Compatible with MagSafe Magnetic Charging) https://www.amazon.co.uk/dp/B07THHQ...abc_1CK164Z2ZM4RDY8NKZT2?_encoding=UTF8&psc=1
6 Jan 2013
Rollergirl
