Google Pixel 6/6 Pro
19 May 2005
Anyone ordered from Currys?
Just realised I can get 7% off via a reloadable card from my workplace, plus I already have £61 on a gift card leftover from a previous purchase. They also still have the coral version in stock by the looks of it.
I did because I had a 10% off code (and 5% cashback). Delivery on the 28th hopefully.
21 Oct 2020
Scree protector installed! Went with the LK TPU ones off Amazon. Highly recommended. I had these on a OnePlus 8 and they worked well. You really do need to watch the video though. Even having installed them I still don't quite get how they work!
12 Feb 2006
Surrey
12 Mar 2008
West sussex
You'd need a notch and I'm willing to bet Google knew the usage stats for the Pixel that had a notch and I bet it wasn't that high.
You don't, OnePlus does face unlock without the notch. Issue is security, it's nowhere near as secure as apples implementation for e.g. but works well enough.
V_R
V_R
17 Jan 2007
UK
Just received my 6 Pro. Its big! Bigger than my 4XL in its chunky Dbrand Grip case! :eek:
I think I might be glad I ordered the non pro this morning....
6 Apr 2006
How is the fingerprint reader?
For me so far.. not good at all.
I will caveat that with the fact that I've installed a glass screen protector, I didn't try it without.
Edit to added, seems much better with pressure, I'm used to the pixel 5 which needs just a glance, I guess these screen readers need more pressure.
12 Mar 2008
West sussex
You need to re-add the finger print if you've installed the protector after setting it up...
21 Jun 2016
Stonehaven
Ordered two non-pro Pixels, one for me and one for the wife. Reviews look great and it will be a solid upgrade from our current Samsung S7's. Never used finger print scanner before, so not too worried about that. Expected delivery is within the hour :)
19 May 2009
Cannock
Ordered 20th but have not been charged or had a dispatch email - apparently its going to magically arrive tomorrow
Was this from Google? I ordered from them as a guest on 19th when the store was dying, managed to get an order confirmed though. No payment pending on my card and they've pushed the delivery back to 28th now. Makes me wonder if something went wrong given how bad the store handled the release day.
6 Apr 2006
I have, afew times and tried to trick of adding the same finger a few times as additional fingers! I definitely feel like it's getting better over time or I'm getting more used to it.
11 Oct 2009
Greater London
Which screen protector is it? With my OP7TP certain protectors didn't work well with the optical scanner, but the UV glue protector I've been using had no issues so far.
