Single tap to wake here, never had issues with it.I'll ask this here as its busier.
Double tap to wake, is it still a thing in 12 or is it just super buggy? Since updating my 4XL it seems really flaky if it works or not.and my 6 Pro seems just as bad.
I bought the Anker 65 watt nano 2 gal charger. It is an amazing charger. Granted i also bought the matching cable from Anker also. but well worth the money. It wasn't much more money than the 45-watt version. A bit of future-proofing i thought. The cable you use with these new chargers matter also btw.
Yep wake works fine here.Single tap to wake here, never had issues with it.
Do you still have the old phone? Copy over the database file and try a local restore.
Hey chaps. My 6 comes today. Recently started to use Google authentication app. Will that copy over or do I need to do a export separately?
Mine did get hot during transfer of files and app install etc but all previous phones I had did the same. Normal use it's been fine. It is a brick compared to p5 but p5 is such a perfect size and no one seems to even try to recreate itPixel 6 arrived today, gets super hot and feels a bit of brick compared to the 5.... Not overly impressed tbh
There's a way now, used to be a pain. I use authy my self and have had no issues with transfering.Hey chaps. My 6 comes today. Recently started to use Google authentication app. Will that copy over or do I need to do a export separately?
Anyone had luck getting a decent case for the 6? Still want the spigen liquid air but it's showing 2 week delivery time on amazon
Spigen Liquid Air Case Compatible with Pixel 6 - Matte Black : Amazon.co.uk: Electronics & Photo
Or if I order that now will it probably come a lot sooner?
The transfer option when you set the phone up does a pretty good job these days.Is there an idiot's guide anywhere for setting it up and transferring everything from an old phone?
I'm going from a mate 20 to the 6 non pro.
