I will be deactivating the e cores as they will be the problem. Pre-ordering the 12600k.
Taking out 20-30% of your CPU doesn't sounds like a good deal...
Interesting. That should just about match/surpass a tuned 5950X with PBO and curve optimizer in games, we shall see.
I suspect finally my 5950X CBR23 ST score of 1715 will be beaten by an Intel processor though. At least until Zen with 3D Cache arrives.
it allows higher tdp allocated to P core, so you can do higher all core overclock on P core which most likely improves game performance
That's an interesting way to try and extract more performance for gaming. Curious to see how it compares over multiple games and workloads.it allows higher tdp allocated to P core, so you can do higher all core overclock on P core which most likely improves game performance
https://videocardz.com/newz/intel-1...cifications-and-pricing-leaks-ahead-of-launch
Looking promising
Hoping AMD can fight back next year with the refreshed Zen3.
Some fair points and questions there, could potentially be a lot of variation depending on how and what is tested.I have questions.
DDR5 or DDR4. JEDEC timings or tighter. Intel MC spec speed or faster?
W11 or W10? If W11 before or after the L3 cache bug was fixed for Zen 3?
PL1/PL2/Tau settings? Intel spec or Motherboard spec?
e-cores on or off?
What I do see is that there is going to be a lot of variation between Anandtech, GN and HUB because they all test differently. Anandtech go with stock everything across the board so that means stock timings, stock MC speed, stock gear ratio, stock PL1, PL2 and tau etc. GN go with stock power settings but run affordable but tuned ram. HUB run with motherboard power settings and affordable but tuned ram as well. Then there is the obvious OS question of do reviewers use W11 across the board or do they run best OS for each platform. Do they run with e-cores on or off or both. So many variables that will probably lead to many follow-up articles / videos for the various outlets.
Looking promising
That explains it when. Any indication as to what extra score the top SKU will offer vs this one?Did you miss that it is a 12600K?
I've no doubt the results are true, but they will be painting their CPUs in the best possible light.Half the games on that slide seem very specific to me.
So this could mean the results are taken on Windows 11, before the Ryzen OS/Chipset updates came out to restore expected performance.
Or it could have been done on Windows 10 and none of that applies. Have to wait and see what is what, but looks like the 5950X might not be the fastest gaming CPU anymore.
I expect it will depend. CS:GO, Valorant and other competitive games are noted by their absence from the slide so perhaps in the arena where high refresh 1080p gaming is really important Zen 3 is still ahead and I expect at 4k it makes not much difference unless you intend to keep your CPU, RAM, Mobo through several GPU upgrades.
I'd rather see how they do in modern games though not ones from 6+ years ago that already run at many 100s of fps even on a potato system.If it had CS:GO and Rocket League +15% on those slides i would be impressed, its difficult to get games like that on the GPU limit, its where the CPU can fully stretch its legs and that's where Zen 3 blows Intel out of the water by some 20 to 30%, Intel would have to gain about 50% performance to convincingly beat Zen 3, the same is true for most games when you set the resolution low again to take the GPU out of the equation, most of what you're looking at from reviews involves the GPU limits, so you're seeing (Zen 3 +10%) so Intel only need +15% to beat it.... no! +15% where the GPU is 70% the bottleneck is not +15% its +4%.
