- 30 Sep 2005
Why? Reviews claim otherwise.
It looks like something I can do in paint, just by copy/paste/stretch
I mean fair enough, the object did vanish, but was replaced by a horrible blob
I have the DPD app and that notified me that I had a parcel coming before the Google store email came in.I think if you download dpd app and register it'll give you details of anything coming your way/your postcode.
I guess you can do that ? Export the picture to your pc, edit and reimport back to your phone?!![]()
#doubtIt would certainly look a million times better![]()
It's going to be highly dependent on the picture, the background and the thing it's removing.It would certainly look a million times better![]()
I've done that and it's coming between 1 & 2. CheersI think if you download dpd app and register it'll give you details of anything coming your way/your postcode.
#doubt
does the 6 pro allow dual sims?
cant find where to install the second one
Yes. Esim + physical sim.
@grudas - NEVER underestimate the power of Microsoft Paint!
Speed not accuracy was the order of the day
original
pixel
paint
The thing is, I don't think you're using the software for what it is intended.
The software is assuming you'd have something you'd want to take a photo of, and then background things to remove that you don't like.
Trying to remove something front and centre that large is of course going to mess up the results as the software is trying to do something else.
So yes the software is poor when used wrong at removing something front and centre.
If you show for its intended purpose then we can better judge
Correctso i cant install a second sim, i have to speak to EE to make it an Esim?
So we're on the same version now. I did wonder if P6 was behind by a bit. I'm annoyed that I can't see the change log.
