Hi there.
I am currently having a go at running Home Assistant off my Raspberry Pi 3.
Having almost given up after realising how complicated it all seemed, I finally have everything set up and have bought a ZZH CC2652R stick, and set up ZigbeeMQTT.
I now need to start buying some devices to actually work with it.
My first idea is a smartbulb for the lamp outside my front door.
I want it to come on as soon as HA senses that the sun as set, on a low dim light (and will stay on all night).
However, I want the bulb to turn on to maximum brightness when it senses that my phone is on its way home.
Can anyone recommend anything bulb that might fit the job, please?
This is the list of compatible devices, which is pretty comprehensive (and includes many brands I have never heard of):
https://zigbee.blakadder.com/zigbee2mqtt.html
Need something that will be cheap to run (given that it will be on all night, every night), and won't burn the place down.
Thanks
Thanks
