Testing charging speeds with a 45W PPS charger.
Pixel specced to take 30W.
Starting from 10%. Let's see how it does. Drawing only 21W so far.
0m 10%
10m 25
20m 42
30m 57%
So that's 47% in 30 mins. Pretty much as advertised.
I've been spoilt my warp65 charging. 15 to 60% in 10 mins.
If my 80 year old dad can do gestures you can too
Glad they straight up got rid of buttons.
That was the first thing I did. Cannot stand all that gesture nonsense.You can turn the buttons back on in the settings if you wish
Also the battery % has been removed from the pulldown unless you have it on all the time in the status bar. Now it's just cluttered.
Weird. I absolutely definitely have no battery % on my status bar, but can see it on the pulldown. What is gone though is the ability to tap the percentage to get to battery stats directly.
I need a charger for my 6 Pro and was going to go with the Google charger. Thinking ahead a little bit and trying to be smart (which is probably not smart at all) would it be worth getting something like the "Choetech USB C Charger PD 100W GaN" charger that can do 1 x 100W or 2 x 45W charging. It doesn't support PPS and I have no idea if that is important or not. My thinking here is not having to buy another charger in the future when the wattage invariably increases yet again and also the ability to charge 2 devices at once. It's £35 vs Google's £25 charger.
App switcher has a screenshot button, will screenshot whichever app is selectedEasiest way to take a screenshot? volume down and power button seems really awkward compared to my previous phone with the power button below the volume buttons.
Are you on the latest update, because mine got removed after update 036
Cancelled my CPW order on the 20th of October. Just received the email that the order has been cancelled. I'm just surprised there was an email at all, not that it is 8 days too late.
There is a build later than SDIA.210817.036?
I am on the November 5th security update, which come down soon after getting the phone on the 26th.
