USB stick has 3 partitions, cant merge
Underboss
20 Oct 2002
Oxfordshire / Bucks
i have a USB stick that i cant seem to put right again
this is how it looks in the disk management software
tried deleting volumes, creating volumes, the middle 3Mb one , i cant even delete or anything
any ideas ?
Would help if you said why you can't delete them, like do you get any error message or maybe something in the event log. :) Either way you could give the portable version of DiskGenius a go.
As EsaT says - use diskpart to clean it.
Be extra careful, if you don't know what you're doing you could wipe something you need the data on.
Thanks
I'll have a look later
There's no data on them at all / don't need anything off it
As for why I can't delete them, it's all greyed out , can't select anything, the only thing I can do is delete the partition and create another, but I can't merge them so it's still in 3 parts
He means data on other drives, because command line applications aren't quite as intuitive as ones with a GUI.
Yes, absolutely.
I've seen people at work accidentally nuke a hard drive by mistake using diskpart, when they meant to wipe a misbehaving USB flash drive...
i think its obvious which drive i want ?
Microsoft Windows [Version 10.0.19042.964]
(c) Microsoft Corporation. All rights reserved.
C:\Windows\system32>diskpart
Microsoft DiskPart version 10.0.19041.964
Copyright (C) Microsoft Corporation.
On computer: DESKTOP-DO881I4
DISKPART> list disk
Disk ### Status Size Free Dyn Gpt
Disk 0 Online 1863 GB 1024 KB
Disk 1 No Media 0 B 0 B
Disk 2 No Media 0 B 0 B
Disk 3 No Media 0 B 0 B
Disk 4 Online 14 GB 14 GB
DISKPART>
Disk 4, hopefully if i do disk 4 it wont touch Disk 0 !! ?
