Who on earth games at 720p
No one games at 720p with a top end GPU but it is a method to test cpu gaming potential.
You're just as bad as Jigger with your distorted/exaggerated claims. No Intel have NOT smashed it all around. They've done well in many aspects but definitely not 'smashed it all around'.Agreed, very solid reviews, Intel have smashed it all around. Looking forward to tinker with mine!
No, that's channels. Literally. Use Google:
https://techxplore.com/news/2020-07-ddr5-sdram-standard-boost-dual-channel.html
>> Each DIMM can handle two 32-bit memory channels instead of only a single 64-bit channel. Since each bank operates independently of each other, the burst length can be doubled and greater efficiency can be achieved. That means, for instance, DDR5 SDRAM can perform two 64-byte operations in the same time it takes DDR4 SDRAM to perform just one operation
In case you weren't aware, this was a huge bottleneck in multithreaded FP operations in all DDR4 systems.
So yeah, not the same thing as dual rank, "mate"
.The area behind Tom’s Diner in CP2077 is the most CPU intensive area in the game even at 4K due to the crowds of NPCs the game spawns in these areas. Yet HUB and the other reviewers only benchmark this game in the City center district where there are hardly any NPCs and the load on CPUs is reduced.If you have the, try Cyberpunk 2077 or WD:L with raytracing maxed out and 100% detail in WD:L, but DLSS ultra performance, and go to an actual in-game area and drive around (say Japan Town in CP, and Westminster for WD:L). Curious to see results.
In case you weren't aware, this was a huge bottleneck in multithreaded FP operations in all DDR4 systems which made bandwidth utilisation very inefficient on non-server grade platforms.
AnandTech said:In the desktop space, we’re used to one memory module having memory for one 64-bit memory channel. That’s true for DDR4, DDR3, DDR2 etc, but the DDR5 specifications move to 32-bit memory channels. So while each DDR5 module is still using 64-bits of bandwidth, there are technically two 32-bit memory channels worth of memory on each module. This can create a little bit of confusion, because it means that Intel 12th Gen, while still a 128-bit memory interface as previous generations, it uses 4x 32-bit channels, not 2x 64-bit. Undoubtedly companies (even Intel) still call this dual-channel, as a channel is usually inferred to be a 64-bit interface.
There is no easy solution here. 2DPC (two modules per channel) doesn’t really mean much if technically channel there infers 64-bit but you’re running on a 2x32-bit channel system. Some users are calling a DDR5 module a ’channel’ with two 32-bit ‘sub-channels’, although that is more a twisting of reality, given that sub-channels are often something else in memory design. Because we’ve used the word ‘module’ to imply a 64-bit channel for so long, and because memory can be installed with more than one module per 64-bit channel.
I'd like to see these power locked to 105 watts like top end Ryzen. Even 125w or 140w. If they used the same power settings as Ryzen these would show quite poorly. Intel are wringing the neck out of their nodes and people are not noticing.
I remember you banging on about how great/important AVX512 will be but yet we see here with ADL that you have to disable E-Cores to use AVX512. So much for that then.... So please stop with the predicting how great all things Intel will be with the distortions and hyperbole. I'm sure I am not the only one that finds it tiresome.
I know difference between Ranks and Channels. I think you need to go read up.
Also I work in I.T and know the difference for at least 40 years![]()
+1You're just as bad as Jigger with your distorted/exaggerated claims. No Intel have NOT smashed it all around. They've done well in many aspects but definitely not 'smashed it all around'.
Congratulations for having 30 years of redundant information.I know difference between Ranks and Channels. I think you need to go read up.
Also I work in I.T and know the difference for at least 40 years.
DDR5 has taken the 64bit channel and turned it into 2 x 32bit.. reality is it is not a true dual channel 64bit each channel (true dual channel would be 2 x 64bit), all they did was half it and tried to make it more efficient.
ADL is still a Dual channel platform/cpu.
https://blog.logicalincrements.com/2019/09/ram-channels-explanation-guide/
You clearly weren't aware of the difference, and confused DDR5's dual channel per DIMM with dual-rank. I'm very well versed in computer architecture. It is you who needs more reading:
From Anandtech:
https://www.anandtech.com/show/1591...sed-setting-the-stage-for-ddr56400-and-beyond
>> The big change here is that, similar to what we’ve seen in other standards like LPDDR4 and GDDR6, a single DIMM is being broken down into 2 channels. Rather than one 64-bit data channel per DIMM, DDR5 will offer two independent 32-bit data channels per DIMM (or 40-bit when factoring in ECC). Meanwhile the burst length for each channel is being doubled from 8 bytes (BL8) to 16 bytes (BL16), meaning that each channel will deliver 64 bytes per operation. Compared to a DDR4 DIMM, then, a DDR5 DIMM running at twice the rated memory speed (identical core speeds) will deliver two 64-byte operations in the time it takes a DDR4 DIMM to deliver one, doubling the effective bandwidth.If you insist on being wrong so be it. But hopefully your 40 years of IT experience will help you understand that on this, you're simply wrong. So man up and read up.
