Do you wish to go DDR5 or stick to DDR4?
Bit bummed the 12700 box is just a cardboard whack affair and the 12900 gets a box with a display wafer!
Box is lovely, fair play. Hope AMD make the Zen4 box something special as well, as could be a good point to build a Ryzen system for me, assuming it's fast in games!
12700KF and K are this years best CPU from Intel full stop, power use is sensible and matches a 12900k in real world without the silly heat and power issues.
I warned people when they were not part of the review kits that Intel was hiding it for a reason, now we know why.. it's their best value and best chip this 12th gen.
That's quite interesting, nice approach. Would dump less heat into a watercooled system.
Pump noise puts me off an aio, I can can have my noctua totally silent.
In that case go for a decent looking board in your budget range for a mobo and whatever DDR5 is available in the size you want. Current batch of all DDR5 is high latency anyway so in a year or so you can shift them on and switch to tighter timed modules and benefit from that.
I might be biased, but for £200 the Gigabyte Gaming-X Z690 has the best pack of features from what I could see when comparing all boards in this price range. It's basically an Auros board without the price tag or fancy aesthetics.
Ive got a few 95nm Intel (real) wafers. You can have one if you want.
Just received this, I decided to go for the MSI board after I had ordered but if I'd cancelled my original order I'd have lost out out on the CPU so a board is being returned.
