I appreciate this has probably been asked a million times, but what is my best option / tactics on getting a chance at a FE 3070 or 3080 ?
And be quick draw McGraw when that notification sounds.FE Part alert on telegram.
Also practice captchas. And if you youre really keen, buy something on the site with your credit card and save it to speed up checkout.
It's hell.
Thanks for the tips chaps. Will get it sorted. How often do stock drops ?
30xx Series Founders EditionThanks for the tips chaps. Will get it sorted. How often do stock drops ?
Is anyone using an after market 12 Pin PCI-E Extension for their 3080/TI and if so, any recommendations?
I really don't like the supplied adapter cable and would like to change it to something in white and individually sleeved like the rest of the cables.
I did use a MODIY one but when I swapped from the NR200 to the 0-11 mini, it was to short!
Probably for good reason, I'm no sparky, but the longer it is, the better the cabling has to be to safely carry the current.
Cable length is unlikely to be a factor, the reason the aftermarket cables fail is mainly down to the cable not being thick enough (cross sectional area) and to a lesser extent the connections not being crimped properly.
You are both sort of right, as cables get longer, internal resistance increases and thus they need to be thicker but in reality for that to be a factor the cable would need to be measured in meters and not centimetres.
As long as its the correct gage (e.g. the same thickness of the PSU cables) and has been assembled correctly, there is no reason why it should spontaneously combust over any other PSU cable.
Any chance of a link to it?I use a cable from cable mod but they're expensive and I don't think they do them in white, well they didn't when I bought mine 6 ago.
Founders senses are tingly.So what are the chances of a Monday drop
